what is best way to get fuel to the carb?? rubber, metal or other?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mike83blazer, Dec 19, 2002.
  1. mike83blazer
    mike83blazer Registered Member
    Nov 16, 2002
    90
    Southern California
    I am currenly running rubber lines and they break constanly, i want something that is low maintenence. Any sugestions?
    Mike Pless
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    where are they breaking? under the truck? from the fuel pump to the carb??
  3. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    The rubber line should be lasting a long time unless it is getting snagged on something. You could always go with a metal line. Take a trip to your local junk yards and find a truck that has one that way you won't have to worry about bending the line.
  4. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    I always try to use as little rubber line as possible.
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    very prudent
    well secured hard line where ever you can and flexible line where movement requires it.
  6. mike83blazer
    Nov 16, 2002
    90
    Southern California
    were can i go for a new hard line? do i have to end it myself? assuming a junk yard does not have one.
  7. RedBrute
    RedBrute 1/2 ton status
    Sep 22, 2002
    346
    Southern tier New York
    I've always preferred steel over rubber. used rubber only where flexing is required (duh) /forums/images/graemlins/grin.gifI went to Napa, and bought regular 3/8 brake line and bent it myself. Use mechanics wire or coat hanger wire to mock up the bends and buy a tubing bender while your there. You can also buy the necesary adapter in brass to go from fuel pump to carb or gas tank to fuel pump.
  8. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    Where is it breaking?
    You can buy a new fuel line that snakes around the block from the mechanical fuel pump to the carburetor for $20 or something like that. I eliminated mine because I use a electric fuel pump now. It isn't easy to get in there.
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    are you trying to duplicate factory or imporove on it?
    I think LMC sells factory style
