What is between the door panels and inside of doors/Door panel installation
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BigTex, Dec 3, 2001.
  1. BigTex
    BigTex 1/2 ton status
    Dec 27, 2000
    974
    South Texas
    Guys, I just installed new coverlay door panels last week but when it rained like crazy yesterday, I noticed a couple of leaks coming from inside the door. I know they came from around the door handle/latch. What is supposed to go between the door panel and the door to eliminate this? What I did (and I thought this would work) is duct-taped a sheet of heavy plastic to the inner door, then I put some "jute" insulation and then the door panel. I also put in a new foam seal but it still leaks a little. Can anyone help?
    <font color=red>"SETTING OFF ALARMS IN A CITY NEAR YOU!"</font color=red>
    <a target="_blank" href=http://coloradok5.com/gallery/BigTex-Mean-Machine>http://coloradok5.com/gallery/BigTex-Mean-Machine</a>
  2. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    I had the panels off a set of newer doors...they had plastic taped there from the factory. The plastic would help reduce drafts and to a certain extent road noise. I'd be looking at the quality of your door seal contact as the culprit.
    Sit inside the truck and have someone use a garden hose along the top edge of the door...
    Also some K5's come with a single rubber seal and some have a secondary seal on the door itself.
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  3. Eric78K5
    Eric78K5 1/2 ton status
    Feb 18, 2000
    230
    South Carolina
    I agree with tRusty...check your door seal. Maybe check the alignment of the door itself too, if it's hard to close at all.
    Eric78K5
    K5-Because Size Matters!
