what is causing the smoke.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Sparky, Nov 15, 2000.
  1. Sparky
    Sparky 1/2 ton status
    Aug 20, 2000
    423
    San Antonio(summer) Texas A and M (school year)
    My blazer never put out any smoke untill recently. Originaly it had the normal amount of smoke at start up due to the seals on the valve guides. Now the smoke does not stop out of the driverside. (true dual exaust) It makes a huge cloud that extends ten feet behind the truck. The smoke is white which would indicate to me coolant or water getting burned, but with the amount of smoke i would suspect it to burn alot more coolant. I can not even notice any coolant loss after driveing it for a couple of days this way, and there is not any radiator fluid in the oil. Could this be caused by the carb being to lean on one side? If the exaust gas is too hot it makes white smoke right? Espessialy when it is cool out. Why would this only happen on one side? Let me know what ya think.
    Sparky
    When all else fails... Check the blinker fluid.
    78 K-5
  2. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Its worth a look...if you have an auto tranny, the modulator's vacuum signal is ported off the back of your intake. If the modulator has gone bad, it will allow tranny fluid to be sucked into the intake and down into a cylinder (obviously one on the left bank of cylinders) and cause your truck to smoke. Its a longshot, but give it a look.
    ken
  3. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    I used to have an old Mercury that did that, it'd burn a quart of tranny fluid a week. I bet that one cylinder was real clean though[​IMG]
    Rene
  4. Sparky
    Aug 20, 2000
    423
    Hrm? Interisting. I would have never thought. I'll check it out. Thanks, but keep the rest of the comments comeing.
    Sparky
    78 K-5
  5. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    OK, another idea...if the left bank of engine is smoking, pull the valve cover and make sure the oil drain back holes are open and clear...if not, this will cause the oil to pool in the top of the heads and oil to run straight down the guides and smoke like hell!! Another idea is that your seals are totally shot, or so old that they are brittle and broke like plastic, causing oil to pour thru into the cylinders. Replacing stem seals is not that big of a deal if that is your problem. Good luck, and let us know what it finally was!!
    ken
  6. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    I'm with you Ken...
    Um... yes officer I know it's too big...
  7. Sparky
    Aug 20, 2000
    423
    Well guys, I found my problem. I have the milk shake syndrom. Yep my coolant has mixed with the oil. I guess the white smoke was coolant burning off. Damn! Time to pull the motor apart over thanksgiving. Hopefully it is just a bad gasket and not a cracked head. I did not think it was the coolant because it was not loosing much. Guess I was wrong. Thanks for the help.
    Sparky
    78 K-5
  8. 82K5
    82K5 1/2 ton status
    191
    kansas city
    did you buy your k5 in tijuana? from 2 guys. one named cheech, the other named chong. is your k5 is made of marijuana? don't worry about the cops. one big whiff of your truck and they'll be stealing your hotdog.
