what is death wobble?
Discussion in 'The Garage' started by fordslayer383, Oct 3, 2005.
    ive heard this term used on here and im just wondering what its refearing tooo
  1. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    DW is when the front end on a straight axle rig jumps up and down. :haha: :haha:
  2. 86Cucvbeater
    86Cucvbeater 1/2 ton status
    May 24, 2005
    428
    north carolina
    the term refers to violent shaking of the front tires at around 25 mph. and it doesnt go away till you come to a complete stop. could be many things causing it
  3. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    You don't know what it is really until it happens, but it's scary.
  4. why the hell would this happen
  5. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    worn steering parts, ball joints, kingpins. pretty much any frontend component
  6. tRustyK5
    Jul 23, 2000
    36,178
    1,386
    E-town baby!
    Scary enough to make a grown man soil himself...
    Most common with D60 front ends, mostly when the king pin springs lose a bit of their ability to preload the bushings. A bump at moderate speeds causes the bushing to momentarily unseat from the kingpin. Once that happens the wheels lose stabilty and start to oscillate side to side and up and down.
    I've heard of similar 'shake' or 'wobble' with the balljoint front ends, but this is usually when more than one steering component is very worn. DW can occur on a very fresh D60, mostly because even new king pin springs and bushings weren't ever designed with 40"+ tires in mind.
    Rene
  7. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    You are right! I built my 60 up all new and went for a test run and DW @ 40 mph :eek1: So I had to shim it a bit and works great for now.
  8. seattle73k5
    seattle73k5 1/2 ton status
    May 6, 2005
    210
    San diego/Camp Pendleton
    what did you shim to get yours to work my front end is all new rebuilt nothing used or reused everything new on the D60 but I havge serious death wobble.
    HELP
  9. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    I have DW myself right now and am about a day away from fixing it for a long time. The major culprit of DW is a misadjusted or worn steering gear box and other front end components that are worn can also cause it or contribute to it. In my case everything has checked out good except for the play i found in my steering gear box so i'm in the middle of rebuilding another gear box as we speak. I will let you guys all know if this fix's my DW and soon after i'm going to do a write up about how to rebuild a power steering gear box. :thumb:
  10. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Because god hates you :mad:
  11. Chaddy
    May 23, 2005
    4,110
    Salt Lake City,Utah
    Take your king pin caps off, get new springs (10$) and some 9/16 thin washers and put 1 on each side then drive it. If it still does it then add 2 .....that is what I had to do and havent had dw for 4 months now and I drive it everyday. I know it will happen again soon I feel it
  12. onlychevy6
    onlychevy6 1/2 ton status
    Mar 29, 2003
    1,293
    Hockley, Texas
    you see people talking about DW in the Dana 60 but how many have experienced with a Dana 44? Just happened to me today.:mad:
  13. tRustyK5
    Jul 23, 2000
    36,178
    1,386
    E-town baby!
    I run a pair of 1/2" fender washers as shims under each cap, haven't had DW since i did that 2 1/2 years ago. I've put ~20,000 miles on since then.
    Rene
  14. MrArmyAnt
    MrArmyAnt 1/2 ton status
    Dec 29, 2004
    662
    Texas, Kick a$$! (Grapevine, DFW; also Norman, OK)
    If this is so common why are we using the dana 60?
  15. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    You mean like on top of the spring???
  16. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    A new steering stabilizer fixed that on mine....
  17. lrazer
    lrazer 1/2 ton status
    Oct 3, 2004
    231
    Mokena, IL
    yea can be caused by a worn or no steering stabilizer
    and unbalanced tires can contribute to it
  18. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    I've had death wobble on a few rigs before, mainly Dana 60 front trucks. Various causes I have had included larger unbalanced tires, worn drag link ends and loose steering box bolts, and I am currently combatting a it in my crew cab... has a bad stabilizer and I probably need to replace and shim king pins as previously mentioned.
  19. primerk5
    primerk5 1/2 ton status
    Jan 13, 2001
    220
    Finksburg MD
    this is crazy I was just trying to solve that problem last night it looks as if my preload bushings are worn. but you guys are saying that the spings may be bad too? how can I tell how tall should they be?
    Why would a fresly redone d60 with all new parts do it that makes no sence to me. If all the parts are new there should be plenty of pressure to hold everything down.
