What is diff in spark plugs?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by spincast375, Sep 14, 2005.
  1. spincast375
    spincast375 1/2 ton status
    Aug 20, 2004
    194
    Tennessee, U.S.A.
    We currently have an AC Delco R45TSX spark plug in our 454.
    The standard AC Delco is an R44T.
    At Autozone, they also offer a Denso Iridium, an AC Delco Rapidfire, and a Champion Double Platinum.
    Can anyone explain the difference in these, and what is the optimum plug for this engine? The 84 Blazer is a dd, but will do some muddin'.
    Thanks.
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Just use the AC Delco R44T. IMHO The best plug made for a V8 truck with older style (non DI) ignitions. if you have a newer style. distributorless ignition the AC Delco Rapid fires work good.
    The other plugs you mentioned are high perfomance modlels designed to extract the most hard earned money, as fast as possible out of your wallet.
  3. Bigg R
    Bigg R Registered Member
    Feb 21, 2005
    34
    Martinsville,Indiana
    Autolite makes the best plugs for a GM, they last a lot longer than AC's!
    Never use a Champion in any thing but a lawnmower!!!!
  4. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    I had the el cheapo autolite's in my blazer then switched to the Bosch Platinum 4's and noticed big difference. Now my blazer is just a little sluggish, before it was really sluggish :p:
  5. 5kerblaz
    5kerblaz Registered Member
    Apr 25, 2005
    14
    Colorado
    I've messed a bit with coils and plugs in the seven years I've had my '87. Stock AC plugs (.035)/stock coil. AC RapidFire (.045)/Stock coil. Autolite copper cores (.045)/Jacobs coil (Jacobs said, "don't use platinum or any other hipo plug." Now I'm back to Autolite copper cores (.045)/stock coil and my truck runs great. I agree with the earlier poster, they're just trying to pad their wallets with yours. I'll stick with copper.
