what is everone running up front POLL
Discussion in 'The Garage' started by big83chevy4x4, May 8, 2003.
  1. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    my truck is going to be an almost daily driver in the summer and a dd in the winter. im thinking arb so that i can run it in 4wd in the winter and have no problems.
  2. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    i have detroits front and rear... works for me. We dont get a lot of snow around here, but even if we got 2' of snow I could put the chains on... i got chains for all 4 tires. /forums/images/graemlins/grin.gif
    j
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I run a lockright in the front and a welded rear. I only ran my truck in 4x4 once this winter in Colorado. I would just get by with 2wd and not use 4x4 unless necessary.
    It only became necessary once. We got 3 feet of snow and I engaged the frontend. Even with 32's I made it out of my driveway and around the side streets with no probs. I liked the front locker then, but I didn't want to use it any other time.
    ARB would be the best bet if you do alot of driving in the winter.
  4. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    Auburn Pro at both ends...
    I Never use 4wd on the Texas Ice...I get around better in 2wd...
  5. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Dana 60 in front, with Powerlok posi. /forums/images/graemlins/eek.gif
  6. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    D44 w/Dana Power-Lok = The closest thing to being locked with out being locked /forums/images/graemlins/thumb.gif and it's rebuildable!! /forums/images/graemlins/thumb.gif /forums/images/graemlins/usaflag.gif
  7. BIGJ
    BIGJ 1/2 ton status Author
    896
    Central Arkansas
    Detroit for two years. Not one single problem with it.
    BIGJ
  8. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I had a powerloc in my old D44, it's the strongest limited slip that I've found, especially if you only run it with 1/2 bottle of additive instead of the whole thing. It had a much stronger bias than the Auburn pro I had in the rear 12 bolt. </font>
  9. 96chevysfa
    96chevysfa 1/2 ton status
    Jan 1, 2003
    230
    so cal
    powerlocke in my 60
  10. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    For the money, and your application, I would go with
    the Detriot Electic Locker.
    The defalt position is Locked, and when you apply 12 volts
    is a Limited Slip. Look around they Are going for less than
    $750.00
  11. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Powertrax no-slip in my 60. So far, I really like it. Its extremely quiet, doesn't bang between forward and reverse like the detroit rear and definately locks both front tires under load... kind of like a plow when turning under power, but drop into 2wd Low range and it turns great.
  12. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    deee-troits front and rear for me! no dumb selnoid or o-rings to fail! /forums/images/graemlins/thumb.gif
