What is everyone Doing to their Rig this winter?
Discussion in 'The Garage' started by mudjunkie 82, Dec 27, 2003.
  1. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    What Mods are everyone doing this winter to their Truck?
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Tuned Port Injection first and for most. If I have any money left after:
    Crossover
    Custom front winch cradle
    Swap 2.5" lift to 5" lift
    Fender hacking
    Replaced welded spiders with Detroit
    Custom rear bumper, tire carrier, gas carrier
    1350 rear driveshaft
    rebuild stock front shaft
    760X joints in front axleshafts
    Shave more metal off 14bff
    etc.
  3. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    get it finnished,and start looking for d60/14ff.mostly be 100% for june 5th. /forums/images/graemlins/grin.gif /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  4. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    today i put in a new (to me) crossmember and new trans mount.. gonna do plugs tomorrow, hopefully by the end of january ill have my quadrajet rebuilt and installed with new exhaust (hedman long tubes, 2.5" true duals through dynomax bullets 12" long and dumps), and new intake manifold (edelbrock performer air gap)
  5. crawlink5
    crawlink5 1/2 ton status
    Oct 9, 2003
    431
    Spring, TX
    Yanked the th350 today. Putting the 700r4 in tomorrow. Headers tomorrow. 2 1/2 exhaust monday. At least thats the time schedule now. I'm fellin kinda old after today.
  6. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    my mods are short and simple.
    1. 305 to 350 TBI swap.
    2. NP208 to NP241 swap.
    3. 5.13 gears
    4. 14 B FF Detroit Locker
    5. Headers for 350
    6. Redo exhaust
    7. Lift
  7. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    nothing much.... just making a stock k5 into an off road truggy /forums/images/graemlins/smile.gif
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    TBI
    Swapping to 1 ton axles with lockers, disc rear, shaved, relocated shock mounts
    swapping to a different, hydraulic clutch 4 speed/205 case
    installing crossover steering
    install hydro assist
    remove body lift
    Considering changing to different front springs. Next summer, going to probably change bodies.
  9. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    if i knew how to weld at all i would have thought about doing the same with my 84 /forums/images/graemlins/thumb.gif
  10. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    Building up my 407 /forums/images/graemlins/laugh.gif
    Pocket porting the heads. Trying to decide if I should run the energizer 260 or the 266. I like the Comp cams, but for the money and the extra 5HP I can't justify the extra $60 for their cam.
    I also need to reprogram my Howell (7730) TBI for the Big Block Beast. /forums/images/graemlins/laugh.gif
    I also need to find some headers (coated preferred) and get them to accept the O2 sensor.
    Then install it and drive it again... damn, I miss that thing.
  11. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    My 84 is a stocker.
    1. Replacing springs and shocks. The springs are factory and are all worn out.
    2. Fixing the wiring to the driver's side PL.
    3. Finding that pesky vacuum leak....... /forums/images/graemlins/angryfire.gif
    Other than that the truck's doing fine. /forums/images/graemlins/thumb.gif
  12. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    Nothing much:
    new rear 1350 driveshaft
    extended front shaft
    bigger altenator
    figure out my heater/cooling system problem
    this spring:
    new cowl hood
    black cherry full paint job
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Oh, that reminds me, forgot some serious items.
    Installing my new bumpers when I get them
    Install my brand new E-12000 winch that I've had on the floor for three months
  14. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    swapping my 10 bolts and 3.42 gears for a D44/ and locked 12 bolt with 4.56 gears /forums/images/graemlins/grin.gif /forums/images/graemlins/laugh.gif. and getting it ready to pretty much hibernate for the next year. /forums/images/graemlins/angryfire.gif /forums/images/graemlins/frown.gif
  15. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Cross over steering- Roll cage, finally putting the winch on thats been laying around for ever.
  16. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    I just retired the /forums/images/graemlins/burb.gif for daily driving so I am planning on pulling out the 454 & rebuilding it with a 496 stroker kit. I am also going to put more lift possible 10 or 12 inch fronts with a shackle flip rear & bigger tires.
  17. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    I think that burbs with 12" of lift and 44" swampers look Awesome /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/burb.gif /forums/images/graemlins/burb.gif /forums/images/graemlins/burb.gif
  18. greywolf
    greywolf 1/2 ton status
    Oct 18, 2001
    1,606
    ST.PAUL TX USA
    E12000 up front
    8000#pto winch in bed
    6" lift and 35s
    and working on my yota
  19. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    Re-mount my KC lights
    5.13 Gears
    Detroit for the Dana 60
    40" tires
    Soft Top
  20. mr_fujisawa
    mr_fujisawa 1/2 ton status
    Sep 1, 2003
    288
    SF CA
    same here.
    swapping the rear 10 bolt for a 12 bolt 4.10 (already put a d/44 up front)
    4" lift
    some skid plates
    35" tires
    and then we'll go from there. /forums/images/graemlins/thumb.gif
