What is everyone using to store your trailer stuff....
Discussion in 'Tow & Trailer' started by Cmoe, Dec 18, 2005.
  1. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    I need to store some stuff on my trailer and wanted to see what others use.... Some type of storage box on tung of trailers....
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    .50 cal ammo boxes, large style. you can weld or drill on them and then seal them back up as they are water tight.
    the next step would be some weatherguard boxes. they make some in a tounge style box that fist up front on a bumper pull.
    Grant
  3. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Can you take a couple of pic's of the boxes your using? What dimensions are we talking about (Large ones)?
  4. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    large ones, it will be a while before i can get to them. i use small ones as well.
    the large ones are 12'' high, 12 long and 6 wide
    Grant
  5. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    I use a tounge box that is raised to allow use of a trailer winch that I installed inside the box.
  6. 6.2puller
    6.2puller 1/2 ton status
    Jul 8, 2004
    569
    New England
    Check these out, weatherproof and weldable. Only thing I don't like is the lid is completly removed to open. I can see it flying off on the highway when I forget to clamp it on. :doah:
  7. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Check what out? Did you forget to add a pic?
  8. 6.2puller
    Jul 8, 2004
    569
    New England
  9. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Thanks! How are you locking it?
  10. 6.2puller
    Jul 8, 2004
    569
    New England
    It is not lockable, I live in the sticks :D
  11. gmcman7202
    gmcman7202 1/2 ton status
    Sep 19, 2005
    181
    The land of FIBS
    i mounted a pickup truck upper bed side mount tool box on the front of my trailer... its up off the deck about 20 inches, and the back of the box is even with the edge of the deck, so its above the jack. i wired it to have spotlights with a switch inside, powered from the 7 pin conector, and put lights on the side of it so i could see it when i was turning sharp. i love the box, holds my chains, weight distribution hitch, tarp, straps, ect... and the best part is the thing is very secure.
  12. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    any pics?
  13. gmcman7202
    Sep 19, 2005
    181
    The land of FIBS
    sorry i am at school, and i wont be back home for 2 weeks to take any.... but i will take some and then post them up
  14. ryanstrucking
    ryanstrucking 1/2 ton status GMOTM Winner
    Feb 2, 2003
    182
    Calgary AB Canada
    Heres what I did for storage on my trailer.
    This is the front of my buddys trailer... For some reason I have pics of his trailer on my computer and not mine.....
    I used 1/4" checker plate and expanded metal for a bottom (makes for easy cleaning of chains).
  15. gmcman7202
    Sep 19, 2005
    181
    The land of FIBS
    ok finally got a pic. sorry it took so long.
  16. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    I like that! I will have to do that too mine. How thick diamond plate did you use?
  17. ryanstrucking
    Feb 2, 2003
    182
    Calgary AB Canada
    I went a little over kill on the checker plate. I used 3/16" but it's all I had in the garage. and the hinge material I used on mine is over kill. as I used 1" tubing....
    Heres a pic of mine. (the one I posted before was my buddies)
  18. mxfireman
    Dec 7, 2002
    2,480
    LHC, AZ
    I like that one a little better. Hinges are mounted in a better spot making the access door larger. Nice job!
  19. eeyore
    eeyore Registered Member
    Sep 18, 2005
    47
    utah
    i have a delta box i bought at a local cal ranch store.i painted it to match the trailer and bolted it to the tongue.it has a weatherproof seal and does lock on the top in the middle.there is a pic in the recent photo galleries i just dont know how to insert it here:doah:.sorry.also the pic is kinda blurry.
