What is fouling my points out?
Discussion in 'The Garage' started by ramses, Nov 17, 2004.
  1. ramses
    ramses 1/2 ton status
    Jul 2, 2004
    238
    West Virginia
    The points on my 73 truck keep fouling out rather quickly. It causes the engine to miss annoyingly when under load. Everytime I replace them it runs great for about a day then back to crap again. Ive replaced everything electrical except the coil, could that foul my points out? I think its the original coil? My uncle said a resistor could cause it but we dont know if my truck has one or not? I know if the distributor has play in it the points will foul so I checked that and it doesnt. Any thoughts anyone?
  2. lugnut
    lugnut 1/2 ton status
    Aug 3, 2001
    268
    North Carolina
    What do the points look like when you take them out ? Are they burnt or oily or what. Are you getting a good set of points or the cheapest thing you can get ? Dont try to save money on points it aint worth it.Did the truck just start doing this ? Did you play with any under hood wiring right before this started ? I think the resistor was built into the wire but Im not sure. A points system has to have a resistor somewhere it could be a resistor wire , a plug in type or it could be inside the coil the coil should have it writen on the side of it has an internal resistor or needs an external one.
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    what is the plug gap and condition?
    is it burning them? WTF is fouled points?
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That's your problem. Without a ballast resistor, you will fry your points on a regular basis.
    Check your voltage at the distributor in the run position, it should be no more than 8 volts.
    You can set them to bypass the resistor for starting only, but in the run position, you MUST use a resistor.
  5. ramses
    Jul 2, 2004
    238
    West Virginia
    The points I put in about a month ago have a small cavity burnt into them, the points I had in for a few months were blistered pretty bad. Im getting the best points. My truck has done this since I brought it home last year but it seems to have gotten worse. Im putting a new coil on it for sure and ill try to see how much voltage im getting at the distributor too. Everything else is in good shape, all the plugs are firing good and everything else electrical is new. Other than the fact I dont know what to set the timing to on a 73, everything is adjusted right.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Stop concentrating on anything except that ballast resistor. A new coil isn't going to do squat for you.
  7. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    it might actually
    coils do not like running without a ballast resistor for very long
    I cooked one bypassing the resistor
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yeah but he knows he has a coil and it's firing. He doesn't know if he has a resistor or not. He needs to do some diagnosis before he replaces parts he may not need.
  9. diesel4me
    Jul 24, 2003
    17,583
    945
    Massachussetts
    I agree its probably a resistor problem,maybe someone replaced the coil with one that had no internal resistor,and the original one did.A condensor that is out of specs will make the points pit and burn also,as will oil fumes getting into the distributor.Might be a good time to upgrade to an HEI distributor--points are antique and costly,and hard to get nowadays-I'd put an HEI distributor in it--no resistor needed,just a 12v hot wire when the key is in the "on" posistion,use a 10 or 12 ga.wire--It will run much better with HEI. /forums/images/graemlins/crazy.gif
  10. bdozeraz
    bdozeraz 1/2 ton status
    Nov 8, 2004
    212
    Phx, Az
    My vote would be for installing an HEI. Don't use the hot wire to the coil for the HEI though because it should be a resistor wire. If the wire has been replaced it could be the problem with your points.
  11. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    with HEI you can"set it and forget it"
    little Ron Popiel reference there /forums/images/graemlins/rotfl.gif /forums/images/graemlins/histerical.gif
  12. ramses
    Jul 2, 2004
    238
    West Virginia
    The points have the condenser made into them so a new one is changed with the points. Thats what is supposed to keep them from getting too much current. Im putting a new coil on it, seeing how it does, then if they foul again im putting a resistor in the wiring harness that will fix it for sure. Eventually I will switch to HEI I have most of the parts.
  13. cheyennesuper
    cheyennesuper Registered Member
    Nov 2, 2004
    52
    Wisconsin
    I have a '73 chevy blazer with point problems too.I can't find a resistor anywhere on the truck...Theres a wire but i can't follow it.Where might it be?I replaced the condenser,point,and coil...
  14. wasted wages
    wasted wages 3/4 ton status
    Dec 3, 2003
    9,194
    Dallas Texas
    I believe on older model trucks the wire had a MEASURED amount of resistance in the wire itself,,,shortening the wire by a few inchs would change the resistance value of the wire,,,also there was a BYPASS wire on the key switch or the starter solenoid that would apply the full 12 volts to the coil for starting and when the key was released it would run on the resistance wire,,,Old school for sure.
    If your points are burning up at the gap of the points the condensor may be bad,,,the condensor "absorbs" the "arc" created by the magnetic field collapsing in the ignition coil every time the points break,,,if the condensor is bad the "arc" will not be "absorbed" and the points will fry.
    Man this is showing my age /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif,,,,I can remember setting up
    many dual point distributors before the advent of electronic ignitions.
    You could find a wire that gets "hot" when the key is switched on and install an inline ballast resistor,,
    if you feel the original setup is not working,,,
    just remember to install the bypass wire I spoke of earlier.
  15. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    hehe, i still have many points setups i play with on a daily basis, being the marine industry is usually about 20 yrs behind the times.. /forums/images/graemlins/rotfl.gif
    i try to get customers to upgrade to electronic asap...
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I used to do that too when I wrenched on boats. /forums/images/graemlins/thumb.gif
  17. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I guess I'll show my age too. /forums/images/graemlins/grin.gif
    Wasted wages is right.
    Back then GM used a resistor wire to the coil. If that wire has been replaced with regular wire or bypassed it will kill the points in a short time. Using no resistance can also fry the coil too. Check the power wire to the coil it should be around 8 0r 9 volts max at the coil.
    Changing the coil will do you no good unless you get one with an internal resistor.
  18. diesel4me
    Jul 24, 2003
    17,583
    945
    Massachussetts
    A set of brand name points around here is about 25 bucks,and special order day wait to get them,since they are 30 old antique parts now at most parts stores--I can buy an HEI distributor from the junkyard,with cap,coil,and even plug wires for less than 30 bucks--unless you love lying on your air cleaner stud while you fool with the points every few weeks,I'd definately get an HEI from a 75-79 GM car or truck before they crush them all--they are starting to get a little hard to find now,and will be priced accordingly pretty soon! /forums/images/graemlins/thinking.gifYou wont regret it--you'll get hotter spark,easier starts,and better gas mileage(if that matters!). /forums/images/graemlins/crazy.gif
  19. azblazer69
    azblazer69 Registered Member
    Jul 10, 2004
    30
    Phoenix, AZ
    Yeah... HEI definetly the way to go... Points are a pain... Dual points, twice the problem... Resistor wire is not very user-friendly even if you can find it, so many ohms per inch? no thanks... At one time you could get a ballast resistor in the "Help" section of your local part store.... I don't know if thats the case anymore... HEI is so much better I have'nt looked back... I had a '55 1/2 ton, a '69 El Camino, and now a '69 Blazer and a '68 commando with a buick v6... All of which I changed to HEI.... zero ignition probs..
  20. ramses
    Jul 2, 2004
    238
    West Virginia
    Well I put a resistor and new coil in and it ran good for a while but now I think its starting to do it again. Its a little different this time though, it runs strong if i go easy on the pedal but if I push it pas about 1/4 of the way down, it just shudders and shakes a lot and has no power to gain any speed. Im gonna check the points again to see if theyre burnt up and go from there again I guess. After I put the resistor on, my tach doesnt work anymore, which is reallly annoying to me now. Im converting to HEI soon but id like to get it to stop for a while until I do. What all exactly do I need for convert it to HEI? I need a list of every part I need. I think I have most of it though.
