what is going on with my starter
Discussion in 'The Garage' started by K-5kid, Apr 24, 2005.
  1. K-5kid
    K-5kid Registered Member
    Mar 24, 2005
    35
    el paso tx
    i have replaced my flywheel i have shimed the hell out of it and it still binds what else can i do. I have dropped the damn thing out probably thirty times to try different shim componations. I have replaced the bolts what else can be done to fix it .I am almost ready to just sell the truck
  2. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Define bind.... Is the bendix gear sticking in the flywheel or just not turning the motor over? Thought I was having a problematic starter last week but turned out to be something totally different.
  3. sweetk30
    Nov 1, 2004
    25,539
    538
    horseheads , ny 14845
    i have never had to shim a gm starter in my time.
  4. K-5kid
    Mar 24, 2005
    35
    el paso tx
    the gear is sticking in the flywheel and wont turn the motor over
  5. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    I have never shimmed a starter either. How many teeth are on your flywheel? Do you have the dual pattern bolt holes?
  6. Mad-Dog
    Mad-Dog 1/2 ton status
    Mar 20, 2005
    548
    Ocklawaha,Fl
    sometimes you have to shim 1 side or the other and sometimes the flange is too thick and must be ground down to bring the starter closer to the ring gear.....
    but it sounds like the motor is not turning the ring gear after the bendix has engaged
  7. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    have some one lay under the truck while u turn it over to see it your flywheel might be bent? or the bearing could be goin in the motor. buddy had the same problem in his blazer. ended up motor was shot.
  8. jk5blazer
    jk5blazer 1/2 ton status
    Jan 28, 2005
    306
    Braselton, Ga
    yeah the starter isn't that much, and I like a few others have never had to shim the starter, not saying you don't but it just doesnt sound right. I would just go buy a new starter and install it w/o any shims and see if that works. And so I understand you right the starter isn't turning over and making a loud grinding noise, the starter gear is ingaging the flywheel and nothing happens, but maybe a buzzing nosie from the starter, right.
  9. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,075
    486
    Grand Rapids area
    Could it be the wrong starter? I know that there is more than one flywheel tooth count out there, but I understood that the same starter works with either. Is it possible that somebody swapped a different starter or different flywheel/flexplate in?
  10. dyeager535
    26,979
    Starters aren't the same. Ring gear diameter is different based on tooth count, and the different nose cones are what make up for that difference. This is *one* of the reasons there are two different starter bolt patterns. Essentially straight across starter bolt pattern is 168 teeth (IIRC) and staggered is 153.
  11. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    fixed it for ya
  12. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I've seen blocks at:
    straight 153
    staggered 153
    straight 168
    staggered 168
    figure that one out lol
  13. K-5kid
    Mar 24, 2005
    35
    el paso tx
    it has the staggered patern but i am going to buy a new starter this weekend and try it all again on the fourth starter hopefuly it will work thats three weeks i havent gone out to red sands
  14. K-5kid
    Mar 24, 2005
    35
    el paso tx
    yea it grinds and the stops trying to turn the motor should i try to grind some off the cone might that work
  15. dyeager535
    26,979
    If the bendix stops when it hits the flywheel, that means that it has too MUCH engagement, right? (thinking out loud here) If you grind the nose cone, (I assume you mean shave metal off where it mates to the block) you end up moving the bendix even closer to the flywheel. So that would mean even worse problems, right?
    At this point, after this many starters, I'd probably stack some washers between the bolts and the starter, make sure it won't hit the flexplate, (could break the block if it gets enough leverage) and see if it throws the bendix out and the starter turns freely when you do this.
    Did this problem all of a sudden just start, or what changes led up to this problem?
    If there was/is a way to get the starter to throw the bendix out, but not rotate, that would be pretty valuable too, you might actually be able to see the teeth engagement, which might tell you something. IIRC though, it's pretty hard to see the starter/flexplate engagement.
  16. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    you sure the block isnt cracked where the starter bolts up? Also, is this a new motor, or high compression motor? Parts store starters cant spin my big block, I hadta go to a mini-starter. When I would turn the key, the starter would engage, and just kinda buzz. Put on a high-torque ministarter, problem solved. Im not sayin go buy a $200 mini-starter, until you cover all teh bases, a buddy of mine happened to have just bought a mini starter for his 55, so I put it on mine, fired it up, took it off and bought one of my own.
    Also, maybe the positive battery cable isnt providing enough current for the starter, just enough to engage, but not enough to turn it.
  17. K-5kid
    Mar 24, 2005
    35
    el paso tx
    do the starters for the 153 and 168 have diferent patterns i havent counted the teeth yet i am going to do that tonight but if i had the starter for the other flywheel that would mess it all up right
  18. dyeager535
    26,979
    *apparently* (did some searching on the net earlier) most GM cars used a 153 tooth flexplate...if you used the starter from a car app, it is probably wrong.
    measurement post number 2
  19. K-5kid
    Mar 24, 2005
    35
    el paso tx
    i looked at it and it looks like the bendix gear is wrong i belive i have a 168 toothbut another site said that the 153 tooth is straight and the 168 is stagered
  20. dyeager535
    26,979
    If you do a search for paperclip and starter you will likely find how to use the paperclip to check the gear engagement. Problem is, I'm not sure how you get the bendix to come out without rotating the engine nor how you get a paperclip in there so you can see, and also, that link I posted mentions measuring the flexplate. I'm not sure how you'd measure either, unless the transmission wasn't in place.
