What is happening to my jimmy??!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dewey, Jan 11, 2001.
  1. dewey
    dewey Registered Member
    Dec 17, 2000
    59
    MA
    This problem just started today..When I'm going highway speed, this shimmy starts. It's like I'm driving over the warning notches in the road on the side, without the noise.. I can make it go away by putting on the brakes, but it comes right back. It only happens at speeds above 45. I don't think it's the wheel bearings. Maybe something in the steering... When I jacked up the front, I have about 1/2 inch play when pushing the tire front to back. any help??
    D.
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    maybe your tie rod ends or the ball joints if you dont think it is your wheel bearings then i would check these
    s.smith 77blazer lookin 4 mud
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    I am going to have to guees that it is maybe a u-joint..
    Do you feel the shake/shimmy through the steering wheel or through the body??
    If through the steering wheel, then it is probably in the front end(toe-rods, wheel joint, wheel bearing, etc.)
    If through the body it is probably a u-joint or a tire/wheel out of balance... Or maybe even a driveshaft out of balance.
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
