what is involved in axle swap on 71
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TheBlazerKid, Dec 18, 2000.
  1. TheBlazerKid
    TheBlazerKid 1/2 ton status
    Apr 26, 2000
    259
    Raymond, Washington
    OK, after much deliberation ( a.k.a. pleading to my dad) I have decided to put a 14 bolt FF and a 3/4 ton dana 44 under my (our) 71 K5. I know its pretty much a bolt up on the later models of blazer but is it the same on mine? I have heard that on the back all you have to do is reposition/weld shock mounts. Is this true or is there far more involved, also how about the front end, is it a bolt up besides driveshafts or is there also a lot involved?
    Thanx in advance
    Theres No Replacement for Cubic Inches!
  2. k5king
    k5king 1/2 ton status
    Jul 23, 2000
    571
    Parkesburg, Pennsylvania
    i think you will also have to move the spring perches to fit your rig,,believe they have to be moved inward a little bit...
    ANYBODY LOSE THEIR JEEP????????[​IMG]
    I JUST FOUND ONE UNDER MY BLAZER!!!![​IMG]
    [​IMG][​IMG]
  3. smp
    smp 1/2 ton status
    Jul 5, 2000
    708
    Florida
    I have a 3/4 14 bolt and a 1 ton 14 bolt and you have to move the spring perches on the 3/4 ton axle but the one ton will bolt right up on my 72
  4. TheBlazerKid
    Apr 26, 2000
    259
    Raymond, Washington
    is the 3/4 ton the SF and the 1 ton the FF??
  5. smp
    smp 1/2 ton status
    Jul 5, 2000
    708
    Florida
    They are both full floaters only thing different is the spring perches you can get semi floater but i wouldn't bother go all the way and some day get the dana 60 up front.
  6. TheBlazerKid
    Apr 26, 2000
    259
    Raymond, Washington
    so is the front a bolt up or not?
  7. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>When I did this on my 71, I used a 1 ton 14 bolt and a 3/4 ton dana 44 front. the rear bolted up, but I needed to shim the pinion up a little and I also had to re-weld the shock mounts. The frontend bolts in for the most part. However, I found that the 73-78 dana 44s have thicker tubes than the pre-73 ones, so I bent the u-bolts a little. You will also need new u-bolts and plates, and a 1310/1350 hybrid u-joint for the rear. If you have any more questions just hit me up the next time you see me online.</font color=blue>
