What is involved in installing a divorced 205?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Jackedup86GMC, Sep 2, 2006.
  1. Jackedup86GMC
    Jackedup86GMC Registered Member
    Jul 27, 2006
    64
    Southeast Texas
    Ok, so I know I need a 2WD tranny; front, rear and middle driveshafts; a divorced 205 with cross member; but what else? What I really need to know is the little stuff, is it really this cut and dry? Any and all information is appreciated. Thanks.
  2. sweetk30
    Nov 1, 2004
    25,554
    548
    horseheads , ny 14845
    yep about that much. best i have seen is mount it in the middle so both main shafts are same length and 1 spare will be needed if you carry a spare.
  3. Col_Sanders
    Col_Sanders 3/4 ton status
    Apr 27, 2005
    5,688
    KFC
    newb question:
    What is the advantage of a divorced transfer case?
  4. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    More Shifters on the floor!:D:D:D
    It separates your selection of Hi & Lo from 2wd & 4wd.
  5. sweetk30
    Nov 1, 2004
    25,554
    548
    i think the last 2 post have the question wrong. not a twin stick shifter setup like you replyed about. but a divorced 205 tcase. the case is held in the frame by its own crossmember and has a stubby drive shaft from any 2x4 tranny to feed it power. this will let you use any 2x4 tranny in front of it.
  6. Jackedup86GMC
    Jul 27, 2006
    64
    Southeast Texas
    The main advantage of a divorced Tcase is it helps alot with severe driveshaft angles. But in a K5 it isn't very practical. Lucky for me I'm installing mine in a LWB pickup, so it won't be a problem. Really it is only needed when you have a tall lift and the front drive shaft keeps spitting u-joints.
  7. BKinzey
    Jan 13, 2006
    3,145
    Hollywierd, CA
    OOPS!:o:o:doah::ignore::ignore:
  8. ccj8008
    ccj8008 1/2 ton status
    Apr 2, 2001
    228
    Polson MT
    I have a crossmember that was used in an international harvester truck or travell all. These all ran divorced Np205's. The interesting thing about these crossmembers is that they go over the top of the t-case, suspending the case below and leaving nothing underneath.
  9. Jackedup86GMC
    Jul 27, 2006
    64
    Southeast Texas
    Do you have any pics of this cross member? That is the way I was thinking of going.
  10. sweetk30
    Nov 1, 2004
    25,554
    548
    pm divorced there is a reason thats his screen name. :haha:
  11. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I have one from a Dodge pickup, I thought it went under but i will take a look at it tonight and then take a pic for you.
    It's really the best option for LWB trucks and especially for a conversion from 2wd.
    They work good on Van conversions :D
  12. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    And it doesn't involve a woman?:doah:
  13. Jackedup86GMC
    Jul 27, 2006
    64
    Southeast Texas
    The cross member seems to be the thing that will give me the most head ache, since it seems I will have to have one fabricated from scratch. Any pics you could post would be much appreciated. Thanks Iceman.
  14. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    It shouldn't be too hard to fab a x-member. There are only four mounting bolts on the t-case, then make some brackets to attach the t-case to some box iron between the frame rails.
  15. divorced
    Jul 20, 2004
    5,115
    Nope, no woman involved... just my extreme fascination with a divorced t-case :D
  16. divorced
    Jul 20, 2004
    5,115
    Here are some pics of the Dodge crossmember...
  17. divorced
    Jul 20, 2004
    5,115
    and more...
  18. divorced
    Jul 20, 2004
    5,115
    These aren't my pics. I had them saved on my computer... they show a home-brew crossmember
  19. Jackedup86GMC
    Jul 27, 2006
    64
    Southeast Texas
    Thank you Divorced!!!!! That is exactly the kind of stuff I was looking for!!!
  20. divorced
    Jul 20, 2004
    5,115
    No problem, sorry it took so long to get some pics up.
    If you fab a crossmember - it is important to build the crossmember to handle side-to-side forces from the torque, but also it's equally important to build it to control the t-case from a front-to-back motion as well. At first mine would "twist" forward until I built it a little stronger. If the crossmember you build needs more support, you can attach a rod from the lower bolt of the front output cover on the rear of the t-case to a point somewhere rearward on the frame to help control front-to-back forces (this is how Ford did it).
