What is it called?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by JTB, Nov 16, 2001.
  1. JTB
    JTB 1/2 ton status
    Dec 5, 2000
    192
    CA
    Hey guys, I need this part that attaches the CV joint to the t-case. My t-case is a 205, the part should have a square plate with four bolt holes on one side and a u-joint connection on the other side. If you have one you will sell, let me know. If you know what it is called, also let me know because I will need to know what to ask for when I go to buy it. Thanks,
    Jeff
  2. cleszkie
    cleszkie 1/2 ton status
    Apr 23, 2001
    121
    Santa Ana, CA, USA
    I think you are talking about a drive shaft yoke.
  3. JTB
    JTB 1/2 ton status
    Dec 5, 2000
    192
    CA
    Anybody have an extra?
    No officer, I don't remember doing donuts on your lawn
  4. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Hey dude,
    I think what you are talking about is called a "flange".
    It isn't a yoke for a u joint, but a flat round plate with 4 holes in it for the CV joint to bolt to...
    Here's a pic of mine (flange off the back of my NP205 for the CV joint) if this is what you are talking about...
    <a target="_blank" href=http://communities.msn.com/Ryans1972Blazer/picsofryansblazer.msnw?action=ShowPhoto&amp;PhotoID=247>http://communities.msn.com/Ryans1972Blazer/picsofryansblazer.msnw?action=ShowPhoto&amp;PhotoID=247</a>
    Mine uses four 12sided 12mm bolts with plenty of loctite to bolt the CV joint to the flange.
    Hope this helps.
  5. JTB
    JTB 1/2 ton status
    Dec 5, 2000
    192
    CA
    Thanks Ryan, for some reason I couldn't open up your page to see the pictures (site could not be found) but I did find my manual. The part I need is not the flange, it is the last part of the CV joint. Maybe a junkyard will have one.
    Jeff
