What is normal engine temp?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Bowtied, Aug 6, 2001.
  1. Bowtied
    Bowtied Registered Member
    May 21, 2001
    69
    NC
    I need to know what is normal for engine temp.
    Here's what I got:
    87 / TBI / 350ci crate / 350 auto
    When running around town and on the highway with the A/C off it is right around 200 F.
    When running around town or on the highway with the A/C on it gets above 200, normally no higher than 235?
    Is this way too hot? If so, what measures should I take to cool it down?
    Thanks!
    Andy
    (Bowtied)
    By the way, it's been above 90 here for the past few days if that factors in.
  2. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,260
    72
    Humboldt/Pacifica, CA
    I think NOT is about 180 degrees.
  3. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Do a rad flush and replace the thermostat with a 195 degree stat and then check it out. After that, replace the water pump. Weirdest thing I ever saw was I had a water pump go out, drove about 1000 miles on it, but the temp wouldn't go above 200 with the heater blasting.
    Bubba Ray Boudreaux,
    Leader of the Advance Party for
    the CSA revolution in the PRK!
    <a target="_blank" href=http://community.webshots.com/user/mdntrdr1>http://community.webshots.com/user/mdntrdr1</a>
  4. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    It is higher than a stock blazer but the crate motor is probably higher performance package.
    The 235 may be getting close to abnormal. Clean the system inside and out and run 70/30 distilled water and coolant with a bottle of Water Wetter from Redline.
    Other things such as timing can affect temp also.
    Dave
    Saw It... Wanted It... Had A Fit... Got It
    91 K5 - in the process of 4" lift with D60/14FF plus LOTS of extras. ETF August 1.
  5. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    I know that most people know this, but I am going to state the obvious anyway(I've seen too many people do this thinking it would help cooling). You must have a thermostat installed. If not the coolant will move through the system so quickly that it won't transfer the heat. The correct temp. t-stat for your truck is 195 degrees.(unless you are running an aftermarket chip) Your fuel injection system won't go into closed loop mode until it gets up to temperature. In this case your fuel mileage will suffer and your emissions will be elevated. If you have the correct(and functional) t-stat installed, then I agree with the post above. Flush the system with a good radiator flush chemical, and refill the system 40/60 mix of water and coolant. Water wetter never hurts either, but you shouldn't have to have it. Good luck!
    '85 K5 : Run it til it breaks, then fix it and go again!
  6. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    240 is concidered over heating so your's is running too hot to me.
    I'm running a high performance motor and she stays right at 190 whether idleing, down the highway, stop and go traffic....all in 100+ degree weather.
    A lot of what these other guys have mentioned are worth checking out. Also, check and make sure you don't have a lot of bugs on the radiator. Then, flush it real good and put in a new thermostat (they're cheap so there's no reason not to) and see what that does. Be sure to mix the antifreeze with water ...50% is the best for me and I'm in hot temps too. Good luck!
    I've got a mind like a . . . a . . . what's that thing called?
    <a target="_blank" href=http://www.geocities.com/muddin4fun79blazer/>http://www.geocities.com/muddin4fun79blazer/</a>
  7. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    Oh, 190 to 212 is about normal temp. It shouldn't fluctuate a bunch.
  8. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    do a flush, change the cap, and the t-stat. you might want to have a pressure check. if you are loosing pressure you will not have correct cooling
  9. shupach
    shupach 1/2 ton status
    Dec 28, 2000
    648
    Dallas, TX
    my 98 burban with a 454 never gets above 210, so i figure around there is normal.
    phill
  10. Itali83
    Itali83 1/2 ton status
    Feb 12, 2001
    795
    Westbrook Maine
    I have to differ with the no thermostat = overheating. when I bought my truck, it had no thermostat in it because of a long story. Well, anyways, the truck never got hotter than 100 degrees. So that is just a myth about the no thermostat = overheating. At least for my truck. Just lettin ya know.
    Ben 87 Jimmy
    <font color=blue>Rust=Bad</font color=blue>
  11. HispanicPanic
    HispanicPanic 1/2 ton status
    Mar 21, 2001
    351
    El Paso, Texas
    my jimmy is always running 160 even in 100 degree weather so anything over 200 for me is over heating
    BEER-- one is none, two is half, and three is one.
    <a target="_blank" href=http://4x4.alloffroad.com>4x4.alloffroad.com</a>
  12. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    I agree with Itali, my Blazer didn't have a thermostat when I got it either, and it would not run above 100 - 120 degrees. Believe me, I know, because I froze my ass off driving it home to Michigan from southern Tennessee. The first thing to check is if your temp gauge is accurate. Factory temp gauges are junk when they are working right, the accuracy is terrible. The way I check mine is to drive until it is reading a hot temperature then stop and release the pressure in the cooling system, remove the cap, and check the temp with another thermometer (I used the meat thermometer from the kitchen). If anyone does this, be very careful removing the cap. Use some rags to surround it completely - HOT ANTIFREEZE will spray out.
    Tim
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
  13. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    I think I run at about 170-185 normally. I pulled my radiator, pathced a pinhole leak, and scrubbed out the fins real good too. Before cleaning out the fins, it would run about 200, and
    move up to 235 in stop and go traffic.
    Your temps sound real high, like what I was getting before the cleaning, but I second the reply about getting an accurate temp reading...
    Wife's car (Pontiac 2.8) runs at 220 normally, though.
    Ratch
    <a target="_blank" href=http://k5.8m.com>k5.8m.com</a>
    **I need a house. Friggin realtor went and sold mine.**
  14. TwoCrowsDesign
    TwoCrowsDesign 1/2 ton status
    Jul 13, 2001
    387
    89 350 tbi stock before new radiator w/ 195 thermostat ~210F
    With new radiator &amp; 185 thermostat ~185F Imagine that!
    John
  15. dyeager535
    26,979
    Well, this article begs to differ with you : ) http://www.dorianyeager.com/index2.html
    No anti-theft measures on your truck? No pity when its stolen
