What is phaseing or lineing up your u-joints?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BobK, Sep 3, 2001.
  1. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    I've heard of guys saying to make sure your u-joints are in phase or lined up.What the heck does that mean?
    <font color=green>BobK<font color=green>
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    They mean on a two piece driveshaft to make shue the u joints are lined up the same way. The ends with the u joints in them should line up.
    86 Jimmy 4"lift 35"MTRs Other cars 69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    even on a 2wd 4 speed shaft ? all three joints in that style of shaft shoudl all be in same position ?
    getting ready to rebuild and install shaft into 71 2wd longbed truck is why i ask.
    anyone know magic tricks to remove old carrier bearing from 4 speed shaft ? i have bench vise, bfh, and torch, so., its being a b*tch to remove on this one
    thanks
  4. greatwhitenorth
    greatwhitenorth 1/2 ton status
    Mar 10, 2002
    102
    Surrey, BC
    I spent three hours removing my carrier bearing if that makes you feel any better...
    If I was thinking at the time I would cut the damn thing off with the torch and saved me the hassle.
    I too would like to hear some tips for the next time I'm in that situation.
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    You need the u-joint crosses that are on the d-shaft to be aligned with each other. When you look at the d-shaft it should look like this.
    0=======0
    With the 0's being the bearing cups facing up.
    If it looks like this
    0=======ll
    You will have a very bad vibe.
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    cool deal, thats what i always assumed was that the caps are supposed to all be the same way, now to figure out way to remove the carrier bearing off the shaft..
    thanks guys
