what is reverse rotation?
Discussion in 'The Garage' started by thezentree, Jan 7, 2004.
  1. thezentree
    thezentree 3/4 ton status
    Sep 19, 2003
    7,198
    NC
    ...what the subject says
    also, whats a good source for gears?
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    reverse rotation (reverse cut) gears, allow you to run a Hi-pinion front end, like a D60 from a ford in the front of your chevrolet..and the gears, since they're upside down, would have to turn backwards, so they have to be cut backwards.. i think thats right.. /forums/images/graemlins/grin.gif
  3. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    Hey, Happy Birthday /forums/images/graemlins/smirk.gif
  4. Confedneck
    Nov 1, 2002
    5,236
    hey thanks.. /forums/images/graemlins/thumb.gif /forums/images/graemlins/truck.gif
  5. benny
    benny Registered Member
    Apr 3, 2002
    18
    VA
    Reverse rotation is one of those terms that only stupid ass ignorant people use. /forums/images/graemlins/thumb.gif That would be because when talking about light truck axles there's no "reverse rotation." Originally I guess it was coined because high pinion diffs use gear sets with the gear teeth cut in a direction that spirals different (opposite) than a regular gearset.. You will sometimes hear these gearsets referred to as "reverse spiral" which is correct. Another okay term is reverse cut because the high pinion gearsets are just cut in a direction opposite of normal low pinion gearsets.. So basically high pinion axles require high pinion gearsets which may be referred to as reverse cut or reverse spiral..
    There's never any "reverse rotation". No matter high pinion or low pinion the ring gear and pinion gear turn the same respective directions..
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    My ring and pinions turn in reverse when I put my truck in reverse. /forums/images/graemlins/rotfl.gif That's, "reverse rotation."
  7. thezentree
    Sep 19, 2003
    7,198
    NC
    ohhhhhhhhh, is THAT what it is /forums/images/graemlins/shocked.gif /forums/images/graemlins/rotfl.gif
    i figured it was something along those lines. so, how bout dem gears?
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    No actually I was being sarcastic. The term is used to describe "reverse cut" gears, even though it is essentially incorrect, as noted above.
  9. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I have heard that there is strength gains from reverse cut gears. Is this true?
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Only when used in a front axle. By design, a regular ring and pinion is stronger in forward than reverse. When a regular ring and pinion (standard cut) is used up front, you're using the weaker side of the gear when you're driving forward.
    Reverse cut allows you to use the stronger side of the gear for a front axle when moving forward, which is usually where the most strength is required.
    The opposite is true about using it in a rear axle. Using a reverse cut axle in the rear effectively means you're using the weaker side of the gear, and a standard cut would be stronger for that application.
    I don't know if that made any sense, but hopefully somebody understands it. I can visualize it in my head, but actually making it mean something in type is difficult.
    EDIT:
    That's why you'll rarely ever see me trying to pull a rig out in reverse. I am installing a winch now, but in the past, I've had some pretty heavy duty tow straps break and done some serious recovery with just my truck by itself (including extracting one Peterson's cover truck, my only chance to brag I've got to do anything cool) /forums/images/graemlins/rotfl.gif I have never broken a thing in the process. Don't know if always using a forward gear has helped this, but i'm sure it hasn't hurt.
  11. thezentree
    Sep 19, 2003
    7,198
    NC
    oh, i know, i was just goin along with it. i aint THAT much of a brick! /forums/images/graemlins/rotfl.gif
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Hey, it takes all kinds of people to make up a world...honestly, on the computer, you never know.
  13. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Jake(hipinion) has a custom built boyce equipment hi pinion D60 that is odviously reverse cut... We should ask him what he thinks of it. /forums/images/graemlins/smile.gif
