What is teh Proper Way to Install Spindel Nuts
Discussion in 'The Garage' started by DuallyK5, Aug 18, 2006.
  1. DuallyK5
    DuallyK5 Registered Member
    Apr 6, 2006
    32
    New Jersey
    What is the proper way and tourque specs to install spindel nuts onto a 1/2 out of a blazer?
  2. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Are you talking about the 8(?) bolts that hold the spindle to the knuckle or the wheel bearing nut and lock ring that screw onto the spindle?
  3. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    get yourself a spindal socket, tighten till you think its tight and then back off like and 8th of an inch....if I remember right.
  4. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Spindle mounting nuts
    To reassemble the spindle: drive the repacked bearing into the spindle and fill the seal end of the spindle with grease. Install the grease seal onto the slinger with the lip toward the spindle. It would be best to replace the axle shaft slinger when the spindle seal is replaced. See Axle Shaft Removal and Overhaul for details. On 1980-82 models, the chamfered side of the thrust washer should be toward the slinger. Replace the spindle and torque the nuts to 33 ft. lbs. (45 Nm) on 1980 models and 65 ft. lbs. (88 Nm) on 1981-87 models.
    Spindle nuts / Wheel Bearings
    Adjust the bearings by rotating the hub and tightening the inner adjusting nut to 50 ft. lbs., then loosening it and retightening to 35 ft. lbs. Next, back the nut off 3/8 turn or less. Turn the nut to the nearest hole in the lockwasher. Install the outer locknut and torque to a minimum of 80 ft. lbs. (108 Nm) on 1980 models, 160-205 ft. lbs. (216-277 Nm) on 1981 and later 1/2 and 3/4 ton models, and 65 ft. lbs. (88 Nm) on 1 ton vehicles. There should be 0.001-0.010 in. bearing end-play. This can be measured with a dial indicator.
  5. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    Readymix! That was solid tech... good to see .
  6. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    I wonder why the one tons get so much less torque on the spindle nuts?
