What is the acceptable angles for drive lines? (pic inside)
Discussion in 'The Garage' started by jjlaughner, Nov 16, 2003.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I had a few vibes after the lift and they are getting worse. When I regear I want to make sure I have the vibes cleared up. I was thinking about a slip/cv rear line and my front spacer should be here wed.
    Things I have done.
    -installed a 3* shim on the front and rear axles
    -dropped the transfercase x-member and installed a new tranny mount
    so when I measure these angles... how is the easiest way and what angles should I be looking for as a tolerence?
    I may still need to replace the zerorate/shim in the back with a 2" X* block (from az-kickin).
    So what do I need to do? /forums/images/graemlins/ears.gif
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    The diff yoke and TC yoke should be with 2* - 3* of each other /forums/images/graemlins/thumb.gif
  3. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    looks like you've got too much angle out of the transfer case. i think the only way your gonna get no vibes is with a CV shaft.if your going to lift it more with a block, make sure you take that into account when you decide the length of the new shaft.
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    Jeremiah, maybe if you could tilt your axle back/up a little ? looks like it would help for at least right now anyways
    loks pretty good under there for a midwestern truck as old as an 87, whats under there for coating ?
  5. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    why not tilt the transfer case a little? loosen the motor mounts so they dont bind, and shim the back of the tcase down maybe 1/4" and see if that helps, tighten everything back up and see what happens..
  6. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    I'd probably do my best to align the pinion and transfer case output so they are in parallel. I have a far worse driveline angle problem right now than you (my pinion is pointed up past the driveshaft) and I don't get a vibration until around 72mph. I'd see about replacing both universals.
    They say universals are only good for 4° but I say 12° is good as long as they're in parallel.
  7. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    I just took the flap wheel on the grinder and sanded down the frame painted it with a rust cap hammerite paint from autozone. The axles got a quick shot of black... you can tell I didn't do too much between the frame rails though /forums/images/graemlins/rotfl.gif
