What is the advantage of running 57's over 56's...in the rear
Discussion in 'The Garage' started by 4GUNZ4X4Z, Jan 2, 2005.
  1. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Just curious what the advantage if anything of running 57's in the rear instead of 56's. Will 57's set the rear axle farther back?
  2. 4GUNZ4X4Z
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Anybody? Search isn't working to well.
  3. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    I run the 57's in the rear, bad axle wrap and they are very soft for a 6000lb rig. But i wouldnt take them out to put in any thing else. I run them backwards to set the rear end back like, 6 inches i think. Combined with the 56's in the front and the zero rate im at 117" wheelbase from the original 106.5" Not much help about the 56's. Sorry man.
    This is a good example, they bend easy
  4. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I love my 57's in the rear. White-Rhyno and I have the same rear suspension and wheelbase, and both run them reversed. Here is a pic of what they look like when they aren't bent to $hit.
    This one sort of shows how the rear tires sit in relation to the fenderwell w/ them reversed
  5. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Very flexy. Consider an anti-wrap bar of some sort if you make the switch. Mine are currently with the short side forward but I think I'm gonna turn them for more wheelbase when I get my new driveshaft
  6. 4GUNZ4X4Z
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    White, now thats a wicked bend in that leaf....
  7. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    ive seen quite a few leafs bend like that when the shackle goes too far and tries to continue around to the top. a limiting strap will cure this, so will a stop for the shackle.
