What is the best 4" to 6" lift for a 1988 chevy 1/2 ton 4x4
Discussion in '1992-Present Chevy & GMC models' started by jsgraphic, Apr 12, 2001.
  1. jsgraphic
    jsgraphic Newbie
    Apr 12, 2001
    What is the best 4\" to 6\" lift for a 1988 chevy 1/2 ton 4x4
    I have a 1988 chevy 1/2 ton 4x4 and I am thinking about putting a lift on it. What is the best 4" to 6" lift I can get for my truck? Thanks
  2. Dip Stick
    Dip Stick Registered Member
    Oct 14, 2001
    73
    Murdock, Florida
    Re: What is the best 4\" to 6\" lift for a 1988 chevy 1/2 ton 4x4
    Depends on what tires you want, what kind of driving you do, and how fat your wallet is.
  3. jbissette
    jbissette 1/2 ton status
    Aug 8, 2001
    101
    Idaho Falls, Idaho
    My wallet is not very fat, but I think that when the time and money are available a solid front axle swap will be done.
  4. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    If you plan on a solid front axle conversion, you better fatten up that wallet. ORU has the kit for locating the springs, axle will cost you something and you'll need to modify steering for the solid axle connection. Then you need springs to mount everything to. If you lift it now, nothing on the front will be used again for a solid axle setup due to the torsion bars used on 88's. Major undertaking to convert, requires good mechanical skills and abilities and not for the light hearted but definitly possible. Figure at least $1500 to do using a Ford D44 axle, $2500 if you go with a Ford D60.
    A good firm grip is my idea of gun control!
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    $2500 and you can lift it cheaply as much as you want....not so bad in my opinion.
    My friends have spent 5000-6000 dollars on lift, tires, gears, LS rear, and wheels.
    I would not waste my money on a 4". 6" is nearly the same cost, the same work, and you'll always want more anyway, so just go 6".
    Tim
  6. Sparky87k5
    May 6, 2001
    726
    I believe I said "Figure at least $1500 to do using a Ford D44 axle, $2500 if you go with a Ford D60." This did not include tires, wheels, LS, or new gears. Key words were "at least", the more mechanical ability you have, the cheaper it gets. No ability, $4000 minimum. Able to manufacture all the required assembly, just the spring and axle costs then. Figure in new front driveshaft too. Bigggg job for small budgets.
  7. jbissette
    Aug 8, 2001
    101
    Idaho Falls, Idaho
    Hey, when I get the money I can get this done. I talked to the wife and she was ok with it when I have the cash.
    88 Chevy K1500, 350 TBI, TH700R4, 3" body lift, 33x12.50x15 Tires
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I understood what you were saying. My friends payed $2500 just to have a 6" IFS kit put on. If you get a D60 from an old Ford F250 it'll probably already have good gears, but you never know.
    I think if I ever considered it, I'd at least try the straight axle route. A lot of work, but, compared to IFS lift, a lot of return on investment too, and I belive that you could do either for around the same amount of money, maybe a little more for the straight axle.
    Tim
  9. Shorts
    Shorts 1/2 ton status
    Oct 16, 2001
    336
    CC & SA, Tx
    i found a brand new 6.5" Dick Cepek race series lift for $800 on the ORC classifieds board...worth a shot:
    <a target="_blank" href=http://www.off-road.com/cgi-bin/classifieds/classifieds.cgi?session_key=&amp;search_and_display_db_button=on&amp;db_id=5369&amp;query=retrieval>http://www.off-road.com/cgi-bin/classifieds/classifieds.cgi?session_key=&amp;search_and_display_db_button=on&amp;db_id=5369&amp;query=retrieval</a>
    <font color=blue>Shorts</font color=blue>
    '94 K1500
  10. 79ChevySB
    79ChevySB 1/2 ton status
    Jul 8, 2001
    178
    Denver CO
    I have looked on the Dick Cepek website and found nothing for there lift kits. Do you know of a website that I can goto to look at this lift kit? Thanks.
  11. ChadH82
    ChadH82 1/2 ton status
    May 9, 2001
    400
    Stillwater, Oklahoma
    I've experienced both types of lifts on my truck and I can honestly say that the SFA was easier to install than the IFS lift. All I had to do was cut the IFS crap off with a plasma cutter then drill some holes. The rest bolted right up. The SFA will be a little more than a good quality IFS lift if you price things right. $800 for brackets, $400 - 600 for springs, $1500 for axle, $50 steering arm, $100 drag link, $50 U-bolt and plates, brake lines, driveshafts, approx. $3500.
    Chad
  12. jbissette
    Aug 8, 2001
    101
    Idaho Falls, Idaho
    Chad, do you have any pictures of your truck?
  13. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    I have to agree on the SFA route. Much more reliable. You get past 4" and you generally run into problems keeping CV axles alive. If you really want you same stock ride and just a little beefer image go for the 3" boddy lift and you can fit 33's easy... a 2" Body lift will fit 32's or 33's most likely.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  14. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I could get that $1500 axle for less than $500 usually...so, I could probably do it for a little less.
    If I was a fan of that bodystyle, I'd probably be doing it.
    Tim
