What is the best swap for an automatic setup
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by mcmlxix, Dec 10, 2001.
  1. mcmlxix
    mcmlxix Registered Member
    Nov 28, 2001
    80
    Las Vegas
    I had figured to buy a parts truck for the 700r4 NP208. Is this the best setup to use? I don't think I will be doing any heavy wheeling. I want to be able to drive it on the highway but still go play in the dirt. I have been looking for a 83 - 91 Blazer/Burb/Jimmy as a drive train doner. When did these change so that you need a computer for the lock up? Can this be bypassed if I find a newer truck. I want the simplest and best automatic setup that will give me an overdrive. Any information or suggestions would be greatly appreciated.
  2. Chris_T
    Chris_T 1/2 ton status
    Mar 17, 2001
    718
    Saskatoon, SK
    I really like my 700R4/NP205. If you're getting the tranny rebuilt then the rear output shaft can be exchanged for an Advance Adaptors shaft that will allow the 205 to bolt directly with a TH350 adaptor. There are several kits out there that allow you to control the lockup on the convertors with engine vacuum and brake switch cutouts (not sure, but painless might make one). Mine is simply plumbed to lock up in 4th and wired to a toggle switch to unlock the convertor briefly if I choose. I'm not sure any 700R4 used a computer to lock up, when they did the tranny was designated a 4L60. Simply the best automatic with OD would be a 4L80E - a TH400 with overdrive, but may be overkill price-wise if you're not going to need the extra strength.
