What is the best tranny cooler for the 6.2?
Discussion in '1982-Present GM Diesel' started by JORGE, May 3, 2003.
  1. JORGE
    JORGE 1/2 ton status
    Jan 10, 2001
    213
    VITORIA-GAZTEIZ(ALAVA)BASQUE COUNTRY,SPAIN
    Hi,
    I,m thinking to installla tranny cooler,and i have a lot of doubts.
    For example,the 700R4 behind of the 6.2 engines suffers more cause the diesel works at low RPM,and the Tranny pump sometimes doesn,t moves the fluid enough good for cooling fine.
    I suppouse these trucks will need a heavy duty cooler for his trannies.What is the best?Any of you guys has tranny cooler in his 6.2? Is any kit which comes with a temperature gauge for install in the board?Where can i found a installation diagram?
    Thanks a lot for all your replys. /forums/images/graemlins/thumb.gif
  2. bigblock454
    bigblock454 Clack Clack Clack Premium Member
    Jun 18, 2002
    546
    16
    Terre Haute IN
    In my opinion these are the best.
    http://store.summitracing.com/partdetail.asp?part=BMM%2D70266
    Most tranny coolers are the tube design with small fins pressed on, this is an poor design. In the B&M listed above the tube is the fin so you don't have thermal conductivity issues trying to conduct the heat from the tube to the fin. Did that make sense?
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Like bb454 mentioned above, stick with a stacked plate auxilliary tranny cooler. The old tube/fin design doesn't cool as well and aren't built as well. I use a Tru-Cool 22,000 GVW made by Long Inc.(FWIW, they manufacture them for B&M too). The kit comes with all the hose and fittings you'll need.
    Make sure you run the aux. cooler in sequence with the in-rad factory cooler.
  4. bigblock454
    Jun 18, 2002
    546
    16
    Terre Haute IN
    Absolutly, this part is key. When installing the cooler you must first go throught the stock radiator/cooler then into the aux unit. Otherwise you end up heating back up the tranny fluid with the engine coolant.
  5. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    [/ QUOTE ] Ive heard this before, but why not eliminate the stock one? Wouldnt that be harder on the trany, more tubbing to pump through. Also better coolinging for the engine maybe.
  6. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I have been told not to eliminate the stock cooler because trans fluid will absorb moisture, and if you don't get it hot enough the moisture will not evaporate out of the fluid which is supposed to be bad for the trans.
  7. JORGE
    Jan 10, 2001
    213
    Then,the auxiliary cooler is connected in line with the return hose wich backs to the tranny with cooled fluid,is correct?
    i mean the circuit will be something like this:
    TRANNY-------Radiator-----Aux cooler
    |___________________________|
    ---- =Hot ATF
    ____ = Cool ATF
    Is correct?
  8. Can Can
    15,552
    136
    There's another reason to use the stock cooler too. If you live in a cold climate like mine, you can actually OVERcool the ATF if you only run an auxilliary cooler. The stock cooler helps the ATF warm up.
    That's another bonus of using a stacked plate cooler. If the ATF doesn't need cooling it will bypass the cooling tubes. So in extreme cold weather, the stock cooler becomes a tranny warmer and a stacked plate cooler is designed to prevent the tranny from being overcooled.
  9. Can Can
    15,552
    136
    Looks like you've got the picture(no pun intended /forums/images/graemlins/wink.gif).
  10. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    Thanks for the info. /forums/images/graemlins/thumb.gif
  11. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Im assuming by "Stacked plate" you mean they are plates inbetween the fins, and by the older style, you mean he ones with fins, but with tubing as the core?
  12. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    I myself went with the BMM-70264 because it contains all the parts needed to do the cooler addition. The 28,000 does not include installation hardware. The 24,000 does.
  13. bigblock454
    Jun 18, 2002
    546
    16
    Terre Haute IN
    Yes, in the stacked the tube is the fin.
  14. JORGE
    Jan 10, 2001
    213
    And for install a Tranny Temp gauge?
    Does it come with any kit?Or is it sold separately?
  15. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    It comes with all the fittings and hoses and instructions.
    No guages though. The guage can be bought and put in with ease when you install the cooler. I think some people put 2 guages on. One for out of the tranny and one that goes back to the tranny.
