What is the circular thing at the bottom of the 14FF pumpkin, on the inside
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BowtieRed, Mar 20, 2003.
  1. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    Title says it all- what is that?
    Oh, and are the axle shafts supposed to be magnetic near the splines?
  2. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    mine was a magnet... /forums/images/graemlins/usaflag.gif
  3. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    mine WAS too- but i broke it in the removal process. I just made a theory- i think it is there to collect all debris from getting in the gears. but it's not in there now, maybe i'll put a HUGE magnet at the bottom of the pumpkin. maybe not.
    oh well, hope it wasn't important
  4. tRustyK5
    Jul 23, 2000
    36,188
    1,393
    E-town baby!
    You removed the magnet??? /forums/images/graemlins/1zhelp.gif
    Rene
  5. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    it broke and fell out.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If you'd seen what was on that magnet the first time I took my cover off my rear 10 bolt you wouldn't wonder what it was!!
  7. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    i'll just buy a new one and weld it down, no biggie
  8. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Weld?
    A magnet?
    That would be silly...
    Mine was all dirty and I just removed it, cleaned all the shavings off of it, and then stuck it back.
    It's a magnet and if your pumpkin isn't plastic or aluminum it should just stay where you put it.
    /forums/images/graemlins/thumb.gif
  9. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    ok, fine i'll just take one off the refrigerator /forums/images/graemlins/thumb.gif
  10. thatK30guy
    Jan 12, 2001
    32,076
    55
    Well, not quite that simple. They are held down in place by epoxy glue rather than welding. /forums/images/graemlins/wink.gif
  11. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    and somehow welding would be worse? explain your logic /forums/images/graemlins/confused.gif
    wait- the epoxy would be EASIER
  12. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    you could probably demagnetize it with welding. All that electricity flowing through it I wouldn't be surprised. I know I have never seen a magnet welded onto anything. And yeah the first time I took my diff cover off the 10 bolt it was covered in shavings.
  13. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    i'd be gas welding
  14. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    why not just epoxy it? be a lot easier than welding, either wayyou have to clean the mating surface well.
  15. thatK30guy
    Jan 12, 2001
    32,076
    55
    I have never heard of welding a magnet. A magnet is a different type of metal.
    I have removed the magnet from quite a few rears when rebuilding them and they were all held in place from the factory by the epoxy glue. Gotta be a reason they used this type of glue from the factory when assembling these axles, you know. /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/thumb.gif
    And yes, to make it EASIER on yourself, use the glue! /forums/images/graemlins/wink.gif
  16. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    Magnets are Iron or Nickel. No one knoes WHY they are magnetic exactly, but they not a different type of metal, they just different properties, welding (non-electical) does nothing except extend the poles. Glue will do, i'll find some kind of glue- don't know what type of magnet i'll use though.
  17. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    It was a magnet. Probably a circular one with epoxy in the middle. GM seemed to only put them in once in a while. Of the 5 ten bolts I've had apart in the last year none of them have had one in them. Nor the 14FF I took apart.
    You can either find a new one and epoxy it or make a strap over it and weld it in. I, myself, suggest going and buying a bingo stick (those things with a magnet in them to retrieve the pieces) and tear it apart. You can usually find them for a buck or two. Just leave it in the bottom of the case. It's strong enough where it isn't going to move unless a spider gear hits it or some other kind of catastrophic carnage.
    Two things kill a magnet. Those are heat and cycling through magnetic fields. Ever notice how a starter never cranks as easy once you've cooked it? Yeap, that's why. Alternators don't have permanent magnets.
    A magnet is pretty simple. It's basically got atoms in it that are all aligned. Some materials will hold this alignment better than others and therefore create a more powerful magnetic field. GM has always been on the bleeding edge of practical strong magnets.
    Stupid electrical engineers anyway. Always making things more complicated than they need to be.
  18. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Even if the electricity wouldn't mess it up, you can't weld to the cast iron housing without special rod anyway.
    Edited to bold the text you apparently missed.
  19. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    I COULD WELD TO THE HOUSING. . . .
    with the special rod.
  20. thatK30guy
    Jan 12, 2001
    32,076
    55
    /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/tongue.gif
