What is the cooling fan size?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by AntAZBlaz, Feb 26, 2002.
  1. AntAZBlaz
    AntAZBlaz 1/2 ton status
    273
    Mesa AZ
    What size cooling fan is in an 86 350
  2. AntAZBlaz
    273
    Mesa AZ
    by the way if you know what flex a lite fan would be the correct replacement let me know?
  3. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    I've got a 76 with a sb400 factory 4 core radiator and A/C and it takes a 19" fan. In my experiance with these trucks and fans 18" SEEMS to be the more common application.
    Mudstud
    <a target="_blank" href=http://communities.msn.com/OffroadK5s/6superliftand33s.msnw>http://communities.msn.com/OffroadK5s/6superliftand33s.msnw</a>
    76K5 6" with 33s, sb400/350/203parttime/3.73-D44/GM12bolt
  4. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    If you want to move lots of air, try a 76 Cad 500 clutch fan. 7 blades 18" wide and works well for heavy duty cooling systems. Dropped my water temp about 5-10 degrees over stock clutch fan while towing in the mountains.
    87 K5, 427/340hp BBC,4.56 D60 & 14BFF, NV4500, NP208, TSM rear disc's,
  5. AntAZBlaz
    273
    Mesa AZ
    thanks for the info where did you pick your fan from? I'd like to order one on line so i can have it for the weekend.
    anthony
  6. Sparky87k5
    May 6, 2001
    726
    I bought mine out of a salvage yard in Canada and then put a new clutch from NAPA on it. Past experience with Flexilite fans has not been very good, especially for towing use. They just don't move enough air.
