What is the difference between these dana 60's?
Discussion in 'The Garage' started by SCOOBYDANNN, Mar 22, 2002.
  1. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Re: What is the difference between these dana 60\'s?
    The non-tapered one could have been converted from a dully to SRW. It is hard to see in that pic of the non-tapered one but when you cut down a dully hub you are left with a thicker hub than normal.
  3. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    From what i know---mine (tapered) came off a civilian truck, and my friends (straight) for sure came from a military. thats about all i can figure out about them.
  4. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Mine came off a CUCV and is tapered.???
  5. Ruthiford
    Ruthiford Registered Member
    Jun 25, 2001
    37
    Denver Co
    The straight hub came off of a Dodge dana 60 (or 61)and the tapered hub came off of a Chevy (the year dodge hub was I think 92-93 prior they had a bolt on locking hub)
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    gotta ask why you care?
    looks to me like a simple retooling of the mold or something
    far as I know the bearings and everything are still the same
    am I missing something?
    I seem to recall a bendix symbol in there somewhere but cannot recall if it was on the hub or just the caliper bracket
    opps wrong it is cast by BUDD as can be seen plainly in the pic, who casts the tapered ones
  7. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    just curious. i didn't think it was anything special, i just noticed something and asked
  8. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    cool
    as you have access to both styles perhaps you can do a comparo to see if one looks better then the other
    maybe check for casting marks on the tapered style to ID the manufacturer
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    Dan, I have seen this and noticed it also.
    From my sightings, GM hubs are tapered and Dodge hubs are straight.
    I have never seen the opposite on the other axle, so it must be the way they were designed.
  10. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    Thats funny. Mine came from CCUV military truck, and it has BUDD cast into the hub and its tapered. I've never seen a non-tapered one before.
    Will
  11. thatK30guy
    Jan 12, 2001
    32,076
    55
    I have a CUCV also and it has tapered hubs.
  12. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    So what year and model trucks can the dodge dana 60 be used on the K5?
  13. thatK30guy
    Jan 12, 2001
    32,076
    55
    You got me by the nut-sack!! /forums/images/icons/tongue.gif
    I have no clue about anything from Dodge. I'm not a Dodge-man, remember? /forums/images/icons/wink.gif /forums/images/icons/laugh.gif
  14. orange_crush
    orange_crush Registered Member
    Jul 1, 2001
    5
    concord, NH
    with a little engineering, any dodge d60 can be put into any K5. two things though... after 92, dodge put the diff on the wrong side and started butchering the left side axle with their wonderfull sleeve-lock device thingy that only dodge can come up with. i have a '78 K5 and am currently fitting a dodge d60 from a mid to late '70's w300. the only catches here (so far) are the fact that the spring seats are spaced 0.5" wider on the dodge axle, and the donor truck had an NP203. so i have to figure out those two, and also whether or not i'll be able to fit 15" wheels around the brakes.
    hope this helps...
    steve
  15. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I have seen a straight hub Chevy Dana 60 over at Roger's. It cam from a 91 1 ton single wheel truck. It was not a CUCV axle. He also said there was not much difference then that and a tapered hub 60. If you want I can try and get some more info on it.
