What is the difference with "half years"?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JakeInAZ, Jan 11, 2003.
  1. JakeInAZ
    JakeInAZ Registered Member
    Jan 11, 2003
    21
    Near Prescott AZ
    What is the difference with \"half years\"?
    I have an 84 and a half K5 Silverado and I was wondering what exactly, if anything is different. It looks a little more like an 85 to me but for the most part it's ALL 84. It came stock with rear sliders with "wings", A/C, "4 on" high beams, a seperate fuse for a refrigerator or aux. heater, power everything, 31 gallon tank, factory leaf spring lift, factory rear tint, cruise, posi-lock rear end, and dual batteries, and two-tone metal flake paint. I'm just trying to figure out what was stock, what was optional, and what was special order. Unfortunately there are no sights that delve that deeply into it. Any help would be appreciated. It's hard to find parts when you can't just walk in and say "it's an 84 K5"....cause then I get home and it's NOTHING like what I just bought. HELLLLP!
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Re: What is the difference with \"half years\"?
    Your truck is what they call a rolling model change. In the middle of the production year, they decided on some changes (have no idea what, but some changes) and made it effective immediately. The guys on the assembly line will then start building it the new way, in the middle of the production run. Thus, rolling model change.
    They did that sometimes with trim level, front bezel treatment, etc.
    Order it for an 85 if you think that's what it takes. That doies kind of suck having to guess.
    If you are buying repro parts, check them out in LMC or another catalog with good pictures/drawing so you can see if that is what yours looks like. If you're buying from the parts store you should be able to return the stuff.
    -- Mike
  3. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    What makes you think it is an 84 1/2? As far as I know, and 84 is an 84, and an 85 is an 85.
  4. JakeInAZ
    Jan 11, 2003
    21
    Near Prescott AZ
    Thanks TX....you gave me enough information that I can at least narrow my search for parts down and attempt comparissons. My mother used to work on the assembly line at GM in california and she said that you are exactly right.
  5. JakeInAZ
    Jan 11, 2003
    21
    Near Prescott AZ
    Well, I know my blazer is a half year because that's what the tag under the hood says and the VIN number also indicates such. So, for future reference there are half year models. At the plants they usually call them line changes.
  6. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Thats interesting. I didnt know that. I guess that would explain some difficulties at the parts store.
  7. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    i seem to have the same prob with my 88...like for a water pump if i ask for a pump from a 88 it dosent work with all the brackets...but an 87 pump works..
  8. JakeInAZ
    Jan 11, 2003
    21
    Near Prescott AZ
    Best thing to do is to remove the part and take it with you.....saves a lot of damn hassles......OH! and bring a measuring tape with you
  9. Blazer1970
    1,600
    Old Mission, MI
    The '87 - '88 thing is because they all think you are talking about an IFS truck if you say '88. Those trucks used serpentine belts.
  10. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i know how hard it is to find parts for something like that.
    only thing is my 76 has an 86 motor in it.
    i went to buy some minor parts, come home to find that they are nithing like the ones on the rig. i looked at the rear main seal while looking at the tranny and see a 1 part rear main seal.
    it is frustraiting at the least part. like said beofre try them as a 85 vice a 84.
    Grant
  11. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    some 85 were first design serpentine(narrower serp belt than usual) some 305 4 bbl engines anyways
    i suspect that rolling changes weould be ones going from one model year to the next on base model trucks or non-special ordered trucks
  12. JakeInAZ
    Jan 11, 2003
    21
    Near Prescott AZ
    I know exactly what you mean about the main seal issue. I had to replace mine recently and I played HELL with it....I was told that it was a one piece (because I thought it was an 84 motor) but it turned out to be two piece. I pulled my whole tranny out, transfer case, and tore the bottom of my engine apart....only to find out it was two piece and all I had to do was remove the oil pan, oil pump, and bearing cap......It's hard when they don't match. Feel free to send me a message any time if you need info.....the only part I haven't replaced thus far is the body and interior itself so I have a bit of experience with the trials and tribulations of mix and match blazers. I'm always here for advice and I'll do my best to assist you in your issues
  13. JakeInAZ
    Jan 11, 2003
    21
    Near Prescott AZ
    My mother worked on the assembly line at GM in the 70's and the best thing I can tell all of you is that ever model that came out, whether it be Silverado, Scottsdale, Custom, Custom Deluxe, Cheyanne, etc. have MANY variations for each model. Also, a majority of Blazer or truck owners made modifications since they purchased them. Check engine codes, VINS, and ask the pros.....then go from there. But again....the best advice is to take the part out and bring it to the parts store with you.....keep a tape measure handy and use a dang piece of string to measure if you have to. We're chevy guys and chevy guys respect Chevy guys....that's all there is to it /forums/images/graemlins/smile.gif
  14. Blazer1970
    1,600
    Old Mission, MI
    All '84s have a two piece rear main seal. One piece started in '86.
  15. schmuck
    schmuck 1/2 ton status
    Nov 11, 2002
    523
    nola(new orleans LA)
    you said factory leaf spring lift what do you mean by that
