What is the difference?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fr8train, Aug 3, 2000.
  1. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    I now have a NP 203(?), thats what the blue label says on the side, and a NP 205. What is the difference? I know both are big, heavy, and made of metal. Thats where the knowledge stops.
  2. James90
    James90 1/2 ton status
    May 18, 2000
    986
    Rocky Mount NC
    the np 203 is full time 4wd and the np205 is part time 4wd
    hope this helps
    [​IMG]Go prepared
    I have a Shotgun a Rifle and a 4WD(K5) and Country Boy Can Survive!!!!
  3. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    The 203 is a fulltime chain driven case, the 205 is a gear driven two speed part time case. The 205 is definately the better of the two.
    creepin' and crawlin'
    Jim
  4. fr8train
    Aug 2, 2000
    1,712
    Maryland
    Thnaks for the help guys. I figure I have a good xfer case a boat anchor.
  5. fr8train
    Aug 2, 2000
    1,712
    Maryland
    Thanks for the help guys. I figure I have a good xfer case a boat anchor.
  6. Grim-Reaper
    7,385
    Atlanta
    Actully your case is tougher than anything but the 205. Let me put it this way. They can handle a couple hundered thousand miles without failure running full time. I wouldn't worry about that case till it fails. It's near impossible to find a 205 that will bolt right up to a TH350 tranny without spending a couple hundred bucks on adaptors on top of the $300 or more that any junk yard that knows how rare one is would want. I hit the local yard today that I deal with a good bit see if he had anything come in that I would be interested in (he did have a 14 with a detroit in and 4.10's :). Asked if they had any in. His comment was wish I had 50 cause I could take the rest of the year off if I did. He did have a 465 and 205 that he would let me have for $400 for everything including the linkages :) I figure I can hagle him down a few bucks.
    Diging it in the dirt with my K5's
    Grim-Reaper
    http://grimsk5s.coloradok5.com/
  7. Kelboski
    Kelboski 1/2 ton status
    306
    Mcdonough,Ga
    how much does a 14 bolt w/ that setup cost usually Grim?
