What is the diffrence?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by wfahlgren, Oct 10, 2001.
  1. wfahlgren
    wfahlgren 1/2 ton status
    Dec 30, 2000
    157
    Northern California
    What is the diffrence between 67-72 springs and 73-91? Can you make 73 springs fit on to a 72? If so what kind of work is involved, is it worth it?
  2. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    the front springs from a 73+ are longer. i think like 2-3 inches. you could put them in a 67-72 but you will need to offset the axel about 1-2 inches, not sure if it's front or back.
    as for the rear i think they are the same.
    ARQ.
    offroad baja!!!
    1-72 4x4 CST Blazer
    2-71 4x4 CST Blazer
    <a target="_blank" href=http://coloradok5.com/gallery/ArqDennis>My Pics</a>
  3. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Well the back of my 72 has spring packs on it that were made for 73 and up. Duno about teh front...
    <a target="_blank" href=http://www.geocities.com/baja/5099>www.geocities.com/baja/5099</a>
  4. JoshA
    JoshA 1/2 ton status
    Apr 9, 2001
    104
    slc,ut
    I put '73-up springs on my '72 blazer... big mistake. they fit ok, the backs are the same, but the fronts are 3" longer. this moved my front axle rearward causing all sorts of steering problems. there are people who have moved the front spring mounts forward to make them work, but there are plenty of spring manufacturers that make stuff for our blazers now so I think that it is completely unnecessary. I think that it was done before because it was hard to find parts for our trucks a few years back.
    -Josh
    '72 blazer 9" lift YOKO mudders 35x12.50 350/sm465/3.73 UTAH
