what is the fastest you pulled a motor?
Discussion in 'The Garage' started by big83chevy4x4, Feb 19, 2004.
  1. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    im working on my friends k10 and we need a 350 to rebuild, i look over and see my old 78 blazer and pull it up into the shop. i started pulling the motor by my self at about 2:30 pm today. im just taking my time (finding tools, not my shop) working kinda slow and i get it done. i clean up the tools and go inside and the clock says 5:30 pm /forums/images/graemlins/yikes.gif it took me 2 hours to pull a motor in someone elses shop. im sure if it was my shop and i knew where everything was it would gone alot faster.
    so what is the fastest youve ever pulled a motor?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I've had a running engine out while it was still warm. 20 minutes max. Three people working and we cut everything.
    To prove how warm it was, one of the last things we did to hook up the chain and lift it was remove the carburator. When the fuel from the fuel hose hit the intake, it boiled.
  3. bshewmaker
    bshewmaker Registered Member
    Sep 11, 2003
    79
    Arkansas
    nothing faster than a demolition derby motor pull. Pull the hood undo the radiator hoses, slash everthing else. Then pull motor and tranny together. 15 min. tops /forums/images/graemlins/yikes.gif
  4. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    what if you were working on it your self and didn't cut anything?
    it surprised me doing it by my self and even got sidetracked alittle /forums/images/graemlins/whistling.gif
  5. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    ya....we do derby's too and can have them out in less than 15 min.
    NITRO
  6. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    you-i can have that motor out in 14 minutes....
    challenger:"i can have that motor out in 13 minutes"
    you-"challenger, take that motor out"
    if your a bit older the above might remind you of a distant game show....if your younger.... /forums/images/graemlins/shame.gif
  7. mojo-jojo
    mojo-jojo 1/2 ton status
    Sep 26, 2003
    101
    PGH PA
    pulled engine out of 82 chevy malibu station wagon 305 2bbl, pulled engine out of 76 chevy 2wd truck 350 4 bbl and put in malibu wagon. 4 1/2 hrs. every thing working but the air conditioning.
  8. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    6 minutes with a blue wrench and engine hoist /forums/images/graemlins/waytogo.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/histerical.gif
    /forums/images/graemlins/doah.gif
  9. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    Pulled the motor out of a 71 chevelle. 350sbc connected to a powerglide tranny. I believe 5 block to bellhousing bolts, 3 torque converter bolts,16 header bolts, 2 engine mount bolts, disconnect 2 radiator hoses, 2 heater core hoses, vacuum hose to tranny. power wire to dist and alternater. And remove hood. Did it myself outside with a truck crane I know it took under 90 mins. In my garage I can guarantee it would be out in under an hour. Granted that is probably one of the easiest engine pulls no AC or emmission stuff, exhaust was easy to remove, big roomy engine bay...I'm sure pulling an engine fron a caravan would be a different matter entirely.
  10. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] Concrete saw is faster. Cuts through exhaust, motor mounts, crossmembers, ...ect like it's warm butter. /forums/images/graemlins/waytogo.gif
  11. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    From a street/strip car about 30-40 minutes without cutting anything. Of course the hood lifts off and there are a minimum of things to disconnect...
  12. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I pulled the motor in my blazer out by myself in about an hour. With friends we've done it in about 20 min. Air tools really helps.
  13. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    my buddy Norm (the one who came with me to pick up the truck) and I took 2 complete running cars, and swapped engines. pulled them both in the garage side by side, pulled the engines, swapped them. had both running and drivable withing 4 1/2 hours.
  14. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    BTW, 2:30-5:30 is 3 hours there, buddy. /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/rolleyes.gif
  15. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Me and a buddy pulled the 289 and the tranny from his 66 'stang in 30 minutes....INCLUDING going to the rental place to rent the hoist AND to return it...so maybe 10-15 minutes of motor pulling time.
  16. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    A friend and myself pulled out a 350 in 30 minutes, and din't cut anything. He worked the top, i worked the bottom.
  17. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif
  18. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    Probably the fastest... somewhere around 40-55 minutes with me, myself and I, using some air tools and undoing everything properly. (but leaving all the accessories attached w/the motor)
  19. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    It's obvious that you guys are just amatuers. /forums/images/graemlins/wink.gif Several years ago one of the car mags had an article on car stripping gangs in and around New York City. They hooked up with one of the gangs and arranged to have them strip a car provided by the magazine. These guys pulled up in front of the car and went to work on it. In just over 17 minutes they had pulled the engine and tranny, entire front clip, the doors and seats, wheels and tires, and the trunk lid and had all of it loaded up and ready to drive away. /forums/images/graemlins/yikes.gif Be careful hwere ya park up there! /forums/images/graemlins/thumb.gif
  20. Larry_in_Tx
    Larry_in_Tx 1/2 ton status
    Oct 24, 2002
    404
    Houston Tx.
    I’ve had one out in a little less than 3hrs by my self but I gotta say when I’m in the garage I’m never further than 15’ from the beer box. It’s kind of hard to be reaching for a world record when you’re reaching for another beer. /forums/images/graemlins/tongue.gif
    The last time I was at the auto show here in town they had a competition between teams stripping cars. It shocked the hell out of me watching them get those things apart so fast and I wasn’t the only one checking on the truck out in the parking lot after it either.
