What is the firing order on the 6.2? Few other questions on maintenance
Discussion in '1982-Present GM Diesel' started by 84CUCV, Oct 14, 2002.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    What is the firing order?I have the water out How do I get it from the block? Or should I just have if flushed out when I am done. My radiator has low mileage on it, but it is full of crap. What is the right way to do it or should I find a shop? Will a 6.5 injection pump give me more power and who makes a good book on the 6.2 and 6.5? Thanks again Mike
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I have the haynes manual, and I think they cover everything you need. As far as how and when to clean the water passages, if you're not rebuilding the engine and have it apart, I would wait till you hook the whole system up and rig a T fitting in the heater return line, and back flush the system with the engine running. There is a Kit that I bought from Walmart that has everything in it and even the instruction. You can use a flushing additive to do that.
  3. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    Its stamped on the intake manifold.
