What is the general price...
Discussion in 'The Garage' started by 84gmcjimmy, Nov 13, 2004.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    For someone to fully rebuild a SBC or BBC?
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    what are you talking re-build?? just seals?? just general clean out??
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    depends... huggies??
    yeah well it depends. Completely stock? Can be fairly cheap. Does the block need to be decked? Valve job need to be done? Bored? Line honed? Not every rebuild needs these things. My 355 rebuild cost like $1800(never should have let dad lead that build). My 383 I estimate around 1K. But I do all my own assembly work(except cam bearings and pressing rods that need it).
  4. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    whats the usual things for a stock block to get done to? Is there anything I should do to get more power out of it?
  5. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    is it a 305 or 350?
  6. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Either a 350, or a 454, I have access for both.
    While we are on the topic, would a Pontiac engine cost more to rebuild because they aren't as common as chevy? Specifically a 455
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Machine work is what costs the big money and it's generally the same no matter what kind of engine.
    Parts are cheap.
  8. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Put a good cam, and PORT fuel injection!! /forums/images/graemlins/peace.gif
  9. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Parts are cheap.
    cheaper for a SBC. Little more for a BBC and even more for Pontiac motor. For a Pontiac motor, you need a new trans or an adapter plate. With the fact that some people crack housings on TH400s I wouldn't want to run an adapter plate. I've never seen the adapter plates they sell though, they could be awesome. Pontiac motors kind of suck though. They had a lot of really crappy emission years. And the really crappy ones are much more common. I've got a crappy Pontiac 400. It has less than 8:1 from the factory.
  10. mrk5
    Apr 20, 2004
    12,331
    1,039
    Northern Colorado
    This spring I had the full machine work treatment done to mine plus: balanced, comp cam including lifters & springs, assembled w/edelbrock intake, distributor install, primed oil pump, and they painted the block (w/primer even, I was impressed). Total bill was around $1800, can't remember the exact price.
  11. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    $750 for generic machining and parts for a SBC. If you're paying someone else to rebuild the motor it's cheaper to go buy a Goodwrench longblock.
  12. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Parts are cheap.
    I have a 2wd BOP th-400 I can modify to work.
    For the engine, I would do whatever I can to cut down the cost. so I would paint it my self. And depending on my knownledge, install whatever I can.
