What is the Most Rust "You" have ever fixed?
Discussion in 'The Garage' started by titus95, Sep 20, 2005.
  1. titus95
    titus95 Registered Member
    Sep 16, 2005
    12
    Lincoln, NE
    ~Sorry to be post happy tonight. But I'm getting ready to take on the long process of restoring my newly acquired 1985 K5 and it has quite a bit of rust. Just wanted to know if anyone else has attempted a good amount of rust and came out with a success story~
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
  3. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    This is what I have now...
    All that is left from when i bought it is the firewall/front footwell and the hood. Which reminds me I should replace the hood one day...:crazy:
    Rene
  4. bigjbear
    Feb 18, 2000
    13,970
    449
    Marietta GA
    Bad rust in the rockers and rear 1/4s. I bought it for parts, then decided to fix it. I shougd have stuck w/ my 1st plan.
    quater panel:
    rocker:
    [​IMG] [​IMG]
    After the after (as in several trail rides), this is the other side but it looked the same. Welded in 4x4 square tube to replace the rocker and mising floor, and some sheetmetal to cover the hole, bolted on a brand new fender, and opened up the rear wheel arch.
  5. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    What is this "rust" that you speak of?........
    :p:
  6. titus95
    Sep 16, 2005
    12
    Lincoln, NE
    Wow!!
    At least I have hope now and know that my Blazer is not out of the question for being fixed! I knew she was rusty and thought it would be a lost cause but I'm going to go through with it. (Back Quarter panels, Rockers, Front Rear Quarters, Tailgate, bottom half of doors). "tRustyK5"--I really like the rockers on yours...how did you do them like that?
  7. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    I initiallly replaced the rockers with new ones when I did the rust repair...then cut them completely out and welded in 3x3 x .125" wall box tube. I've landed on them hard, pivoted the truck on them and can lift the whole one side of the truck off the groundwith a hi-lift under them...plus they won't rust near as fast as 24 guage.
    Here you can see how they're welded to the body, and you can also see the splice weld where I welded the rear half of a '73 to the front half of my truck.
    Rene
  8. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Be careful my friend, us rustbelt dwellers can cast an oxidation spell in your neighborhood with a simple wave of the brown wand....it spreads like a bad virus, park one rotted vehicle near you and your infected... :D
  9. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    They talked about doing this on UK10 in Petersen's too. Do you just weld the square tube to the body, or does it get attached to the frame somehow also? The frame is quite a way in there, but it seems strange to support the weight of the truck by the body?
  10. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    No it doesnt go to the frame but it gets welded to the body and the main part which is the body support pieces that run to the body mounts. This makes them very strong.
    I used 3x3x3/16" and I wish I had went with 1/4" as I have a few dents and deep scrapes in mine.
  11. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Would someone mind posting a pic of the underneath? I might want to do this when my rockers rot off again. ;)
  12. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    When welded to the body they spread the impact load along their entire length. Supports back to the frame would be good for 'side impact'...
    On the underside you will see the two body mount sheet metal box sections. They end at the back side of the stock rocker. I butted the tubing up against the body mount assembly, welded to the body mounts and along the body on the outside.
    Spend any more than two minutes under your truck and it'll become painfully obvious. :wink1:
    Rene
  13. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    i just ripped the body off(literally) and put a new one on.mine was beyond repair. :laugh: you could open the door and stand behind the steering wheel. :haha:
  14. Brocky
    Brocky 1/2 ton status
    May 22, 2005
    1,170
    St.John's Newfoundland, Canada
    I was looking at cutting my k5 right across from the rockers for rock sliders. I was looking at pics of this and the door overhands over the rock sliders. It looks kind of out of place seeing the fenders and quarter panels are cut aswell. I am currently getting the metal together to do this and was wondering if anyone ran into this problem and can you just cut the bottom off the door.
  15. k30bb468
    k30bb468 1/2 ton status Premium Member
    Oct 2, 2004
    955
    NW Pennsylvania
    Here's my first attempt at some rust repair
  16. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    The rockers on the crew cab were completely gone. I did the rectangular tube rockers. Lots of welding.
    I should add, to get all of the rust or enough to make it worth while the tubes had to go in quite a ways and high! Now I have to go back and trim 3/4" off the bottom of all the doors to get them to close.
  17. boggerless
    May 26, 2003
    22,728
    96
    looks great, mine was way to gone. the body pulled off with my friends truck like it was un bolted. :laugh: :laugh:
  18. wazzabie
    wazzabie 1/2 ton status Premium Member
    Apr 17, 2001
    1,719
    5
    Washington State
    This is some outstanding work. Very impresive. You make it look so easy but I sure it is not.
  19. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Thanks.
    Here is what he ended up doing for it. He spray lined the entire thing, turned out sweet looking.
    PICS
  20. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    :haha: Yeah, well we've got smog...... :doah:
