What is the point of 'wristing' a front axle??
Discussion in 'The Garage' started by TX Mudder, May 7, 2003.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    What is the point of \'wristing\' a front axle??
    CLICK HERE for a write up on a bronco front end.
    Someone help me out here - why?
    -- Mike
  2. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Re: What is the point of \'wristing\' a front axle??
    Wow. Never seen that before. I have seen people on the Fords run a wristed radius arm, but never the front axle. My friend has a wristed arm on his early Bronc and it makes a WORLD of difference in the front suspension travel!
  3. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    The stock Bronco radius arms act like a big "swaybar" when the front axle articulates. The "wristed" stuff stops the binding....
    Marv
  4. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> It seems that on a radius arm suspension such as on the EBs, that would free up alot of flex. The way the radius arms attach to the axle, when the axle is flexed the radius armas are trying to twist the housing in two different directions, so by wristing it you free up alot of bind. Neat idea. It would be useless on a leaf sprung and marginally useful on a multi link suspension, but for that type of suspension it's a great idea. </font>
  5. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    I saw that guy with his setup at last years offroad expo and when I asked him "why not just go to 4 link?" he couldn't give me an answer. Also take a minute and think about what will happen to the steering geometry from one side to the other... one side will try to turn left/right, while the other will try to lay over on its side. What will the tie rod have to say about that??? Just thinking out loud /forums/images/graemlins/smirk.gif
  6. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Ill get the low-down from him at our meeting on monday and let ya know the real deal.
  7. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    As stated above, it frees up the bind in the stock front suspension. As to whether it would have "twist toe", yes it would, but you'll be going slow enough most of the time when there's enough toe change to wonder about that I doubt it would be an issue.
    Under an EB is kind of cramped. Room to do a 3 or 4 link is not easily found. And what would you gain ? Only advantage I can see is better control of the Castor curve. Krawler folks don't seem to be too worried about that and the radius arm design works pefectly well for all but speed in the rough, ala dez racing, when properly modified for the lift used.
