What is the safest length camp trailer I can pull with my K5??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shane74, Oct 15, 2002.
  1. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    I have gathered from previous posts that 20' is the max, but I am curious if it will make any difference whether it is a tandem axle or not?
  2. Can Can
    15,555
    156
    Cochrane, Alberta, Canada
    Length isn't as big a deal as weight. My old travel trailer was a 22ft lightweight that weighed in fully loaded at around 3500 lbs. I personally wouldn't tow anything more than 5000lbs with my K5.
    I would also strongly advise you to avoid choosing a longer single axle travel trailer with a Blazer. Single axle trailers have a tendancy to sway, and the short wheebase of a K5 isn't enough to compensate for trailer sway.
    Regardless of what you choose, make sure you spend the money and buy a good quality weight-distribution hitch. This type of hitch "spreads" the weight across all the axles and keeps the necessary weight on the front end which is important on a short wheelbase vehicle.
    I would also recommend you pick up a Tekonsha Voyager brake controller- it's the best controller on the market.
    Hope all this rambling helps, brother!!! /forums/images/graemlins/smile.gif
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Exactly /forums/images/graemlins/thumb.gif
  4. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    I pull a 21ft trailer popup camper and i keep it at or below 65 to componsate for its squirrely ness above 65....it also has trailer brakes so that helps...the more trailer axles the better stability wise....also a wieght distributing hitch as mentioned is extrememly helpful
  5. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    or a Tekonsha Prodigy. I love mine!!! /forums/images/graemlins/wink.gif
  6. vdubbin86
    vdubbin86 Registered Member
    May 25, 2002
    55
    Alberta, Canada
    I pull a 22' tandem axle with mine. Has a gvwr of 5600lbs and a dry weight of 3600. With a wight distributing hitch I have no troubles with sway. I only get a little pull to the side if a tractor trailer blows by me.
  7. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Thanks for the info. I already have a weight-distribution hitch. I love that thing! Yes, tandem axle with brakes are an absolute must. I was mainly concerned about weight/length. I don't like to tow much over 4500 lbs with mine, so 5000 or less is in the area I was thinking. I found a newer 19' tandem axle set up that weighs in around 3500# I used to tow my 19' boat, but it would get a little squirrely at times. Then again, I didn't have my weight distribution hitch at the time and it was a single axle trailer. I just want to be on the safe side is all.
    Thanks for the education guys! /forums/images/graemlins/thumb.gif
