What is the sensor...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mastiff, Jul 22, 2003.
  1. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    ..that is plugged into the engine block between the front two plugs on the driver's side? It's just got one wire going to it.
    I only thought I had a knock sensor, which I thought was underneath someplace. The computer thingy is all dismantled, so no point having worthless sensors all over. On the other hand, I want to keep my oil pressure and coolant temp guages. /forums/images/graemlins/grin.gif
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    If this sensor you are talking about is on the driver side near the oil pan rail and about half way back that is the knock sensor. If you are talking about the sensor between the front two driver side spark plugs then that is your temperature sensor.
  3. jkce457
    jkce457 1/2 ton status
    Nov 22, 2002
    135
    Southbury, CT
    It's your coolant temp. sensor.
    - Justin
  4. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    - Justin
    Thanks. /forums/images/graemlins/grin.gif
  5. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    No, right up top, between the plugs. The wire comes from above.
  6. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Just to clarify...that's the coolant temp sensor for the gauge alone.
    The coolant temp sensor for the ECM is on top of the intake manifold next to the thermostat. /forums/images/graemlins/thumb.gif
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    what heavy says, its just for stock dash temp guage
  8. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Thanks everyone. I don't have the silly ECM guage. At least not anymore. /forums/images/graemlins/grin.gif
