What is the standard seat taper angle for lugnuts?
Discussion in 'The Garage' started by Shaggy, Apr 21, 2003.
  1. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Title says it all, I need to verify that the standard seat angle on Chevy truck lugnuts is 60 degrees. Thanks!</font>
  2. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
    Evan, I just measured one on the comparator and 60 degrees is correct.
  3. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Excellent! Thanks a bunch, Bill. /forums/images/graemlins/thumb.gif
    Just to make sure that we're on the same page, that's the included angle, right? I'm sure that all tapers are measured the same, but I just have to verify...
    [​IMG] </font>
  4. 45acp
    Jan 3, 2001
    695
    Tucson, Arizona
    Evan, Yes it is 30 on a side or 60 included. Be careful if your going to cut tapers with a single fluted chamfer tool like you showed a picture of. They do not always cut the angle that they are ground for because they push away from the hole you are cutting. It is better to use a multi flute tool for this and it will cut equal on all sides.
  5. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> They push away from the hole? I would think that on something like this, since I'm rechamfering an existing chamfer that it would work fine, but I'm no expert. I got it from McMaster-Carr and there was a thing that said that the single fluted tools work better for handheld use, so that's the one I got. Hopefully it works OK, I'll try it out and if it does a crappy job then I'll have to get another one. I swear, the final days of this project are bleeding me dry. /forums/images/graemlins/1zhelp.gif </font>
  6. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    It pushes away because it only cuts on one side. Whereas a 2 flute would cut evenly on both sides thus centering the cutter. Good luck with the hand drill method... /forums/images/graemlins/ignore.gif
  7. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Great, I knew I shouldn't have bought the tool already. If I had a drill press or access to a mill then I would use one, but I am working with what I have here. </font>
  8. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Why don't you use pop in-laws mill? A 2 flute wouldn't be too bad with a hand drill but with a single it might be but! Since you already have a taper there it won't be near as hard since it will help center it. Just watch it and check the fit of the lug nut often. If it's wobbly don't go so far as to remove too much material making it impossible to clean up...
  9. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Father in law's house is 150 miles away, otherwise I would go there. I'll just try it by hand and see what happens. </font>
  10. 45acp
    Jan 3, 2001
    695
    Tucson, Arizona
    Evan, I thought that you were tapering new holes. If your just enlarging old holes with a taper already in them you will be fine if you go slow. The slower the RPM the better for this case. If your using a hand drill be sure to keep it vertical and don't push to hard or get in a hurry and you will be OK.
  11. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Cool, that's good to hear. My drill has a bubble level on the back of it so keeping the drill straight up should not be a problem,;and I always drill real slow with lots of cutting oil, so hopefully I won't kill the tool before all 32 holes are done. /forums/images/graemlins/crazy.gif </font>
  12. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Why don't you invest in a drill press? You don't need an expensive one. I paid $100 for mine.
    YOu would just need to make sure it would be tall enough so that you could set a wheel in there, obviously.
    They don't take up a lot of room. And would be much easier than hand drilling 32 holes!
    Just a thought.
    -- Mike
  13. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> If I had anywhere to put it then I would, but I don't, so I can't. /forums/images/graemlins/tongue.gif My garage is pretty packed as it is, unfortunately.</font>
