What is the tallest, skinniest 15" tire?
Discussion in 'The Garage' started by SilverMiner, Jul 20, 2006.
  1. SilverMiner
    SilverMiner Registered Member
    Oct 2, 2005
    25
    North Idaho
    Like the title says, I'm interested in finding the tallest, skinniest tire I can run on a 15x8 rim.
    I know Interco makes a 35x10.50x15 in their SSR series, but I'd like to hear of some other options. Does anyone make a ~35" tire with a tread width less than 10"? I suspect there might be something in a metric, but I'm not sure what the magic combination of section width / aspect ratio to search for. If there are more options available in a 16" rim, I may consider that also, as I'm currently running 255/85R16's - but I'd sure like to go back to the classic Ralleye wheels.
    So I'm sure you're wondering WHY DOES THIS IDIOT WANT TO RUN PIZZA CUTTERS ON A K5???
    Well, in nearly 25 years of working in the Northern Rockies of Montana, Idaho and Wyoming I've learned that 90% of the time when 4WD is REQUIRED to get where I absolutely NEED to be (working in the mining industry), it's because there is snow or ice on the ground. And nothing beats a narrow tread width for those conditions, whether it's creeping down I-25 in a blizzard trying to make it to Casper or bombing up a narrow drill road after 12" of fresh snow has fallen.
    Anyone else admit to having a tall/skinny fetish?
  2. stockk5
    Apr 13, 2004
    2,035
    71
    Cromwell, CT
    i dont like the way they look, but fuction over form for u....when u put big tall skinny tires on ur truck, u have to drive around playing "she thinks my tractors sexy":D
  3. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
  4. Quackaddict
    Quackaddict 1/2 ton status
    Apr 2, 2006
    160
    Glenn Heights, Texas
    I know Super Swamper Boggers come in 38.5-11. I also remember SS had a TSL that was 9.5 wide just don't remember how tall they were. Lifted Dually's have to run a skinny tire so yeah there are some out there..........or I could take 2 seconds and see the person above me already said all this..............hey it's late.
  5. SilverMiner
    Oct 2, 2005
    25
    North Idaho
    Interco seems to be the leader in the tall/skinny market, no doubt. I'd forgotten about lifted Dually's - but that means a 16" rim, and for whatever reason I've got a strong urge to go back to the classic 15" Ralleye's.
  6. skidpan
    skidpan 1/2 ton status
    Sep 21, 2005
    226
    SOCAL
    the military tires are tall and skinny
    i have a set of 325/85 but they are 16.
    see if you can get ahold of the ralleye's in a 16
  7. diesel4me
    Jul 24, 2003
    17,553
    939
    Massachussetts
    new ??
    I had some old bias ply 9:00/15's I found on an old "P"series step van at a boneyard I ran on my 72 K5 for a few winters--they were THE best snow tires I'd had on any of my trucks!--tall and skinny is definately better in the snow than wide tires are..the 900:15's were about 31- 32" tall--they rode like steel tank treads,being bias ply with nylon cords!--but you could run curbs over and never hurt them!--they had an 8 ply rating!..
    I tried using 700:750/19.5" tires on my 74 K20 ,that I got from another old 60's Step Van,a 1 ton duallie..but the rims hit the calipers,since they were designed for drum brakes..after buying spacers,I decided I didn't trust having them held on by only half the threads on the lugs,and I didn't feel it was worth trying to find longer wheel studs,so I ended up taking them off..the truck looked VERY aggressive with the 19.5's though--looked like I'd lifted it 4",without doing anything but put the tires and rims on it..they didn't rub either,and I only had a 3" body lift...I wished I had tried getting longer studs,but lack of funds prevented it..
    I found some 6 lug 16.5" wheels after that,and ran 8.75 / 16.5 tires --they were only about 30" tall,but skinny..only about 6" wide!..
    I could outplow bigger trucks with big wide tires and lift kits--they would slide sideways,my truck went straight as an arrow..:D ..if I really wanted to show off,I'd put tire chains on all 4 tires..it was more like a bulldozer than a truck then!..:crazy:
  8. Citizen Rider
    May 5, 2005
    1,415
    Plano, Texas
    http://intercotire.com/site32.php Dually tires-
    34x9.50-15
  9. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    yeah, those michelins are always thin for their height. Look at a 48" michelin vs a 49" irok (aka baloon!) sometime. :thumb:
    j
  10. peter redman
    peter redman Registered Member
    Dec 28, 2002
    11
    duncan,b.c.
    qr78-15 Buckshot Mudders.36 inch tall and skinny. I had them on a 87 GMC 3/4 ton and they worked great in the Ontario,Canada winters.Once I drove 2 miles to work before I realised I had a rear flat.
  11. AFUFO
    AFUFO 1/2 ton status
    Apr 26, 2006
    329
    Chesapeake,Virginia
  12. SilverMiner
    Oct 2, 2005
    25
    North Idaho
    Thanks for all the great links!
    I think what I'll do in order to scratch my itch for the 15" Ralleye is run them with a set of 35x12.50-15's in the summer, and continue to use my 255/85R16's in the winter. I've already got an good set of chains for that size tire anyway, so it would probably make the most sense money wise.
    Thanks again
