What is the thing on the driverside head of my CUCV. with a pic now
Discussion in '1982-Present GM Diesel' started by 84CUCV, Apr 30, 2006.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    Back on the head by the firewall is a something that wireing from the glow plugs plug into. What is it called and what does it do? I think it might be the reason my truck will not start. i tried everything else.........
    thx
  2. Ronnie4wd
    Ronnie4wd 1/2 ton status GMOTM Winner
    Jun 4, 2002
    749
    Stockholm.Sweden
    :dunno: Maybe it´s the glowplugrelay or you maybe call it glowplugcontroller.
    "edit" sorry I read your other posts and they show that you already knew that.
  3. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Here is a pic for you guys. the thing with the white top. thx
  4. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    That is a temperature sensor. I'm not too familiar with the CUCV wiring, but it is either for your cold start solenoid in the injection pump, or it is for the glow plug controller. I doubt it would keep your truck from starting.
    Mike
  5. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Temp inhibit switch. Controls the cold advance as well as affects glow time if the motor is warm.
    Rene
  6. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    So could it affect it when starting?
  7. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    Where does it plug into the IP? My truck has a gasser harness and if I could get that bitch hooked up that would be nice.
  8. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    My bad, I just went and looked at mine and i have nothing plugged into the two pole sensor Mike pictured. I got it confused with the '84 down glow plug controller I have which looks similar except it has about 6 wires coming out of it. The dark green wire coming from there goes to the two other spade connectors on the IP, one does the cold advance and the other kicks the idle up a little IIRC.
    Rene
  9. dieselponyexpress
    dieselponyexpress 1/2 ton status
    Jan 26, 2004
    220
    Germany
    Yes it could. If you're using the original cucv glow module, the switch can shorten or lengthen glow duration.
    A defective temperature switch shouldn't prevent a cold engine from starting though.
    Reading your earlier postings, I'm wondering if your (new) glow plugs even do cycle on.:confused:
    During operation of the plugs you should have ALL of the following:
    - "wait" light comes on after you turned the key
    - a visible drop at the voltmeter
    - a klicking sound from the glow plug relay?
    If not, have you tried rene's advice and ran 12v from the junction block to the relay? Don't connect it to the big junction block on the firewall right behind the rear battery, this are 24v! :doah:
    You should either use the small junction block behind the hydroboost or (better) run a heavier gauge from the + post of the front battery or the - post of the rear battery.
    Maybe you could do some electrical measurements in comparison with your M1028?
    Another thing you can do is to jump the relay. Connect a gauge with a 12v feed between the 2 large posts of the relay. You should hear a clicking sound. Have a helper start the engine after 10-15 seconds of jumping the relay. With all good plugs she should start like a charm . . .:wink1:
    If this doesn't help, test your plugs again. I'm doing this by connecting one plug after another to a 12v battery (tip to +, thread to ground). A good plug glows in about 5 seconds from top to bottom. Use some pliers, these things are getting HOT!
    Good luck.
    Walter
  10. afroman006
    Aug 21, 2002
    2,876
    Is that a "on,off" style switch, as in can it be used to turn an electric fan on or off? It seems like it wouldnt work because it works the opposite of a fan switch, it turns on when the motor is cold and off when it is hot.
  11. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    I will see what happens and let you guys know. thx
