What is the tourqe spec for Dana 60 U-Bolt plate bolts?
Discussion in 'The Garage' started by 1-ton, Oct 13, 2005.
  1. 1-ton
    Apr 17, 2004
    2,890
    169
    Las Vegas, Nevada
    Does anybody know what the tourqe specification for the bolts (or studs) on the right side U-Bolt plate on a Dana 60? I am guessing it is about 75 Ft. Lbs, but I would rather not guess.
  2. 1-ton
    Apr 17, 2004
    2,890
    169
    Las Vegas, Nevada
  3. highrlr
    highrlr 1/2 ton status
    Nov 29, 2004
    302
    Bismarck, ND
    75 should work, I put mine at 80. Just go back and recheck them after a short drive. Oh and I stripped out both of my holes with just a ratchet before I eve started torqueing them, the cast iron seems to be very brittle. I just repaired them with helicoils and seemed to work good.
  4. 1-ton
    Apr 17, 2004
    2,890
    169
    Las Vegas, Nevada
  5. 1-ton
    Apr 17, 2004
    2,890
    169
    Las Vegas, Nevada
    I tourqed all the front U-Bolts to 150 Ft. Lbs, and I started with 85 Ft. Lbs. on the studs, but the 150 Ft. Lbs. on the U-Bolt brought the studs up to 90 Ft. Lbs. I figure if a cast iron block can handle tourqe ratings of 90 Ft. Lbs, then so should my Dana 60 housing. Thanks for the reply.
