what is the...
Discussion in 'The Lounge' started by NEK5, Sep 25, 2006.
  1. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    thinnest plywood i can get?
  2. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    1/4" but you can get luan which is 1/8", why what are you needing it for?
  3. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Lift blocks...:D
  4. 79k20350
    Nov 22, 2004
    7,757
    Ct
    I cant say id be suprised....:rolleyes::doah::haha::haha:
  5. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    and why is that?
  6. 79k20350
    Nov 22, 2004
    7,757
    Ct
    Just a joke man;)
  7. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    i think i`ll go with 1/4 or 3/8...the reason i ask is i`m using it for the half top i got for the wall, it should be fine if i seal it real good right? i heard durabak bedliner is good for sealing wood
  8. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    :D :D ok, i was actually thinking about using it for AALs:D :D
  9. 79k20350
    Nov 22, 2004
    7,757
    Ct
    go thicker, 5/8 or 3/4. it will be much sturdier, provide more sound reduction, and insulate better. bedliner should work fine for sealing it.
  10. 79k20350
    Nov 22, 2004
    7,757
    Ct
    :haha:
  11. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    the only problem is, i need to get it into the window channel in the blazer cap, or should i just go with my original plan of making a bigger wall, then getting another sheet to go in for the window then fasten them together....or should i just reinforce the back(inside) of the wall with 3/4, or both front and back?
  12. 79k20350
    Nov 22, 2004
    7,757
    Ct
    Im not sure of the wall you gonna cover with ply wood so ill say... You could
    1. notch the plywood to fit in the groove (multiple runs through a table saw or a dado blade, or even easier, a router
    2. use plywood below and plexi above.
  13. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    hmm, i wish i had know before i cut up my piece of 4x8x3/4:doah: :doah: that seems like a good idea, but i think that i`ll need the flexibility of the 3/8ths to make it work the way i want to,so i think i`ll reinforce it with the 3/4
  14. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    Pictures might help in this situation, I do believe.
  15. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    well, it looks like i`m gonna have to go with 3/8 or 1/2in becuause its actually going to need to bend straight a little, because of the angle the back window is in the blazer fiberglass top, so...79k20350, anything i can do to strengthen it up?? like maybe screw a piece of 3/4in to the inside of the wall, just below where the window will go? or just use some strapping and make up a little frame type deal?
