What is this and what does it do ????
Discussion in 'The Garage' started by pornorob, May 22, 2005.
  1. pornorob
    pornorob 1/2 ton status
    Jul 12, 2001
    215
    ;jkl;
    I don;t know what this is . Can anyone tell me what it is, what it does , and if I need it?
  2. kgblazerfive
    kgblazerfive keymaster Premium Member GMOTM Winner
    Dec 2, 2004
    10,613
    602
    Hooper, Utah 84315
    EGR valve, recirculates exhaust gas,
  3. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    to answer the "do i need it" (for smog purposes) yes, absolutely required
    (for drivability) no, not required, but doesnt hurt anything either (provided its working)
  4. pornorob
    Jul 12, 2001
    215
    ;jkl;
    I;ve been having some serious hesitation problems could a faulty egr valve be causing it
  5. dyeager535
    26,978
    You said the choke was removed too...as in the choke blade is gone, or you've tied it open, or the element is all thats gone?
  6. pornorob
    Jul 12, 2001
    215
    ;jkl;
    the choke blade is gone I put the choke housing back on just to plug the vacuum port in the side.
  7. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    Are we still talking about the picture above??
    Eric M.
  8. pornorob
    Jul 12, 2001
    215
    ;jkl;
    nope that is an old picture.
  9. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Thank you! Everyone thinks it "robs power!" :surepal:
  10. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    technically, it does. it obviously weighs something, and weight reduces the amount of usable power. so technically, removing it would create more power. but the gain would be so minute, a chassis dyno might not even show a gain. just thought i'd get technical on ya. :p:
  11. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    Since the vehicle wouldn't actually be moving on the dyno I don't think that massive amount of weight would even be a factor... :grin: :grin: Now under real conditions.........
  12. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    on a dyno, the suspension will load, and unload just like it normally would, thus weight will transfer. and actually, a vehicle is moving on the dyno. the rollers are just absorbing the momentum.
  13. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    You guys crack me up! :D
  14. toddol1971
    toddol1971 Registered Member
    Dec 12, 2004
    20
    plainfield Il
    i read this & dont know if anyone answered your ? so Hesitation can be from the egr valve. remove the vacuum hose from it & plug it. If the hesitation goes away buy a new egr valve.
  15. diesel4me
    Jul 24, 2003
    17,546
    936
    Massachussetts
    Remove it and block it off...
    Simply unplugging the vacuum hose may not be enough..if its stuck partly open by carbon deposits,it will allow exhaust gas to enter the intake ALL the time,causing an "internal" vacuum leak!..this can cause hesitation and stalling,among other things--you need to remove it and make a block off plate to REALLY test it--or at least clean all the carbon off the "plunger" thing so your sure its fully seated,and remove and plug the hose to it.....
    I feel the EGR valve DOES kill a bit of power,since its sending already mostly burned exhaust gases back into the motor--the main purpose of it is to lower combustion chamber temparature to prevent "pinging" and high NOX emissions,I've noticed more power on my 305 when I removed and blocked it off(had too,to allow my edelbrock performer carb to fit,it hit the EGR valve!)--my truck is a 79,and emission exempt--your state may vary!.. :crazy:
  16. dyeager535
    26,978
    Under ideal conditions (everything in working order) EGR cannot hurt performance. It's vacuum or electronically controlled, when the engine is under load vacuum signal is lost, and the EGR can't possibly operate. Same as vac advance. It's a cruise-only device.
    IF it's not working correctly, it can stick and cause problems, but you should notice that with a poor idle, and testing it while the engine is operating (by pushing up on the diaphram under the top) should degrade idle quality.
