what is this behind the glove box
Discussion in 'The Garage' started by tunedportk5, Aug 14, 2004.
  1. tunedportk5
    tunedportk5 1/2 ton status
    Jul 13, 2004
    371
    Union City, CA
    what is this computer behind the glove box, is it to control the transmission, I'm looking for a good spot to put the ECM for the TPI /forums/images/graemlins/dunno.gif web page
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    That would be the ECM for your computer controlled carb and distributor.
  3. tunedportk5
    Jul 13, 2004
    371
    Union City, CA
    is there a computer for the trans
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    No , not until much later (1990's) . The trans your year would have lockup and overdrive , but no computer . Even on tuned port Camaros there were no trans computers until the 1990's . /forums/images/graemlins/k5.gif
  5. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    hmm, paul does my 86 have that? I have the carb on and it runs /forums/images/graemlins/thinking.gif
  6. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    It is the ESC (electronic spark control) box. If it is an 86 it might also control the carb.
    It is not for the trans. It is for the distributor. It is there to retard your timing if the knock sensor senses a knock in the motor. Started sometime in the early 80's I believe. Maybe 81 with the new body design. My 85 had it.
    Harley
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    My box is still in the truck ESC only for ignition , my distributor is in the garage, luckily my model had a factory non-computer carb motor , fuse box shows it , but they are blank . Truck came with only the spark system . /forums/images/graemlins/k5.gif
  8. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Yes it is supposed to apparently in your model . Not all will have computer carbs , but all will have spark retard computers in our years /forums/images/graemlins/k5.gif
  9. dyeager535
    26,980
    Thats ESC AFAIK. Don't know of any 80's ECM that is that small.
    I don't believe the ESC holder (that plastic piece) will work with an actual ECM, (even though the plastic looks physically large enough) but get that plastic piece from a TBI truck (people always leave those when they strip TBI off of trucks) and bolt it all in.
  10. tremor
    tremor Registered Member
    Mar 20, 2004
    10
    CT
    How can we tell if the carb is computer controlled? I'm just about to dive into an '85. I'm patial to ripping off the original carb but would prefer a truck that runs to one that suffers from "cummunication issues". /forums/images/graemlins/woot.gif
    Why did I ever sell that smog exempt government 1 Ton van? Grrr. /forums/images/graemlins/dunno.gif
  11. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    A feedback carburetor will have a mixture control solenoid on the side of it. Bunch of wires and crap to it also.
  12. dyeager535
    26,980
    As well as TPS on the drivers side. MC solenoid is on the passenger side top front of carb.
    Don't confuse the dual capacity carbs with the CCC carbs. Dual capacity looks like it has the mixture control solenoid because it has wires there, but does not, and does not have TPS.
  13. tunedportk5
    Jul 13, 2004
    371
    Union City, CA
    yea the ECM didn't fit in the plastic deal for the disributer, went to the junk yard today and found one from a TBI truck bolts right up. /forums/images/graemlins/woot.gif
  14. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,086
    487
    Grand Rapids area
    Only a California truck will have the dreaded CCC.
  15. xflatrater
    xflatrater Registered Member
    Nov 28, 2003
    65
    Shamong NJ
    [/ QUOTE ] CORRECT!!
  16. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    Hmm, on the subject of this post My 86 doesn't seem to have one of these boxes (I'll have to check) but the dist does have an extra plug that connects to nothing. I have no harness that will fit it under the hood. Can the dist run ok without that box or should I look for another dist?
