What is this bolt?
Discussion in 'The Garage' started by LKJR, Aug 24, 2002.
  1. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    What is this bolt next to the timing chain cover? Can I mount to this? web page
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    link dont work /forums/images/icons/frown.gif
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    is it the old front mount bolt bosses from before the side mount days?
    usually unused IIRC
    oh you image thief. yes that is the old front engine mount locations
    nice catch
  4. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    LOL< yea that pic is from chilifest here in lubbock, that is actually my friend chris and my brother. LOTS Of fine ladies here in Texas, espically in a college town.
    Thanks for the engine pic by the way
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    NP
    glad to help if i can
  6. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    yes you can, it is unused, ive seen a few rigs where gm had used it for air pump bracketry but only a few. it is however an ez spot to chip off, so be nice, no impact id sasy.
  7. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    I've heard that that is a through hole and you can pin the fuel pump push rod with too long a bolt...
    Jim
  8. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Yep and you use that hole with a longer bolt when you change the fuel pump..
  9. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
    True. It is there to retain the fuel pump pushrod to facilitate pump replacement. Use some pooky on it if you take it out.
  10. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    thanks guys, I"m thinking about running a bracket down there for my OBA bracket
  11. thatK30guy
    Jan 12, 2001
    32,076
    55
    Just make sure whatever you do, reinstall the bolt or something to plug that hole back up. /forums/images/icons/shocked.gif
    A friend of mine installed a gasket kit on his SBC and forgot to install this bolt back in that hole. He had oil leakage, badly, and at first he did not know where the oil was coming from. He later found the oil coming out of the hole and quickly put a bolt back in. It fixed the leak, but not until he lost a few quarts of oil first. /forums/images/icons/laugh.gif
  12. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    Sweet, thanks guys this just solved my whole problem
