What is this engine built for?
Discussion in 'The Garage' started by Paxx, Sep 26, 2003.
  1. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    All Over Western Canada
    Well I'm picking up my new k5 tomorrow /forums/images/graemlins/grin.gif I was just wondering what this engine is built for (torque, top end, etc.) Here's the stats
    350 cubic inches:(.030" overbore for a total of 355ci )
    Balanced and blueprinted by King Balancing
    Isky Camshaft: 262 supercam(P/N201262): .290 lift, 262° duration, 108° lobe center
    Edelbrock Performer #2101 Intake Manifold
    9:1 compression ratio
    Standard Chevrolet Heads
    Quadrajet 4MV, 750 CFM carburetor
    I don't really know anything about this kind of stuff so if any of you could let me know.. /forums/images/graemlins/thumb.gif
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    whats it have for exhaust? an .03 overbore is standard cleaning/rebuilding bore..a little more torquey than standard bore though..
  3. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    Judging by the lift numbers I'd say the duration spec's are 'advertised', not at .050", which makes that cam pretty mild.
    Stock heads and carb with slightly higher than stock compression ratio. Should idle smooth and pull well off idle and probably run out of useable rpm around 4500 rpm.
    Rene
  4. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    So it should be a fairly reliable engine for my daily driver, with a little more go than stock, right? /forums/images/graemlins/pimp1.gif
  5. Confedneck
    Nov 1, 2002
    5,236
    that would be a correct assumption
  6. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    little more yeah. Pretty close to my motor(I have headers, intake, diff but similar cam, new carb, and port matching), and it gets up a little better than stock. I'm happy with it. I'd be happier with a lot more power but thats not in the cards right now.
  7. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    Its a low end torque engine. The stock heads and mild camshaft will create optimal velocities at lower RPMs giving you a nice torque range. Perfect for a truck.
  8. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    I love that sig /forums/images/graemlins/rotfl.gif. Kinda weirds you out the first time you see it!
