what is this on my engine block
Discussion in 'The Garage' started by mattman4x4, Dec 12, 2006.
  1. mattman4x4
    mattman4x4 1/2 ton status
    Feb 16, 2005
    186
    Salisbury MD
    Hi
    this is on my engine block between the 1 and 3 cylinder, help what is it?
  2. dremu
    Feb 27, 2000
    15,967
    459
    East of San Francisco
    Temperature sender for the gauge cluster.
    Should be a green wire somewhere for it.
    -- A
  3. buefchris
    buefchris 1/2 ton status GMOTM Winner
    Dec 28, 2005
    1,503
    buena park ca.
    sending unit for water temp .
  4. mattman4x4
    Feb 16, 2005
    186
    Salisbury MD
    Well it has a black wire, and I hooked it up and the temp gauge on the dash is not working...How do I tell if its the gauge, wiering, or sender?
    thanks
  5. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    BTW, thats not in the block....its in the head.
  6. dyeager535
    26,980
    Typically that wire is green. Have the truck off, wire off, then turn the key on, note where the gauge is, then apply the wire while the engine is in "run". (doesn't need to be running) If you get no movement, it's likely something in the gauge wiring or the gauge.
    Does it have the right connector on it for that "nailhead" on the sender?
  7. mattman4x4
    Feb 16, 2005
    186
    Salisbury MD
    Thanks for pointing out my error, it is the head on the driver side. Sometimes I type before I think!
    Mattman4x4
