What is this part for?
Discussion in 'The Garage' started by scoutillac, Mar 23, 2004.
  1. scoutillac
    scoutillac 1/2 ton status
    Feb 24, 2004
    423
    Spokane, Wa.
  2. scoutillac
    Feb 24, 2004
    423
    Spokane, Wa.
    Does anyone know what the heck this part is for? If it was still wired in the 90 Blazer it would be mounted behind the stereo area I believe. The engine starts and runs with it plugged in and the other plug empty. Could this be for the stereo? Someonereplied earlier and thought it was an ignition part, but then deleted their post. HELP! I don't want any excess crap wiring If I don't need it. /forums/images/graemlins/ears.gif
  3. Can Can
    15,555
    149
    Cochrane, Alberta, Canada
    It looks a lot like an ESC(Electronic Spark Control) module. Although seeing that your rig is a 90 it might be something else.....
    On my 84 the ESC automatically retards the timing when the knock sensor detects pinging.
  4. dyeager535
    26,982
    191
    It's the DRAC. Don't toss it, you can't get them anymore and they can be modded for any tire size/ratio apparently.
    Anyways, it's essentially the same thing as VSS. Necessary for TBI to run correctly.
  5. scoutillac
    Feb 24, 2004
    423
    Spokane, Wa.
    What does DRAC stand for? /forums/images/graemlins/dunno.gif
  6. dyeager535
    26,982
    191
    Probably something like Digital Ratio XXXX Converter.
    It tells the ECM how fast the vehicle is moving, and also controls the electronic speedometer. (Also a worthwhile swap IMO)
  7. scoutillac
    Feb 24, 2004
    423
    Spokane, Wa.
    Can I get an after market speedo to work with this component? After all the complete harnes and running gear is in a 63 scout. There is no room to mount the original dash pod. I wonder if there is a harness to go from the factory plug to after market guages.
    P.S. Thanks for you help. I have some understanding of what the hell is going on now. The GM parts counter couldn't even cross reference the part #.
  8. dyeager535
    26,982
    191
    Check out the VSS chapter over at www.jagsthatrun.com
    I would bet the connector that is missing in your picture *probably* went to the speedometer, or ECM, and what is on there is one or the other.
    Should be speedo's made to work with it, GM used the DRAC from about 1990 to 1993 or maybe even later, some people must have wanted an aftermarket speedo! /forums/images/graemlins/smile.gif
  9. skelly1
    skelly1 1/2 ton status
    Sep 2, 2002
    554
    San Diego, CA
    So, how does one go about calibrating this thing for bigger tires? Where does it reside in the vehicle? I've never seen it before in mine.
  10. frankin5
    frankin5 Super Mall Crawler Premium Member
    Oct 15, 2002
    883
    114
    chico,calif
    drac= Digital Ratio Adapter Controller /forums/images/graemlins/k5.gif
