What is this part?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by renny, Oct 10, 2004.
  1. renny
    renny Registered Member
    Apr 20, 2004
    30
    Salem, Oregon
    On my vacuum diagram label its called a tip in solenoid it mounts to the firewall on my 1985 K5 and has a vacuum hose going in one side and two wires coming out the other side.
    My Haynes manual doesn't mention anything about it. Thanks in advance.
    Ren
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    sounds like the vacuum sensor for the old E.S.C. (Electronic Spark Control) ignition system. This replaced the vacumm advance.
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    If you have two , one on each side of the truck . The one on the drivers side is for the lockup on the trans , and I believe the other one is like Henry said /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif
  4. zach78k5
    zach78k5 1/2 ton status
    May 14, 2000
    406
    Can the one for the lockup be disconnected? I am using a holley projection so most of the vacuum came out. can I connect the tranny lockup to the intake vacuum or to something else?
  5. dyeager535
    26,982
    191
    The vacuum source for the switch can come from any manifold vacuum source, but if you are running the 700, you need to leave that switch functional, if thats what you were asking.
