What is this?? pics..
Discussion in 'The Garage' started by stockk5, Oct 14, 2005.
  1. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    Alright well im trying to figure out what kinda lift this is.. i see a 4" block i think and is that a add a leaf? Or a 2" lift spring.. i was trying to buy the lift from a kid, and he's saying its 6" total.. im not to sure, i never see and add a leaf installed.. just wondering what you guys would think it is..
  2. monster man
    monster man 1/2 ton status
    Oct 20, 2003
    282
    Reno, NV
    I think it's an add-a-leaf, my K20 has a 3/4" thick add a leaf looks just like that my uncle added, but it also has a 1/2" thick bottom leaf for the HD springs from the factory
  3. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    looks like an add a leaf to me, you can tell its sepreate from the spring pack.
  4. johnathan
    johnathan 1/2 ton status
    Sep 26, 2005
    376
    Ocean Springs,MS
    My springs look just like that 84 k5.So you say tose are add-a-leafs :rolleyes: mmmmmm interesting
  5. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    The very bottom leafs are the factory overloads that came in all rear spring packs. If theres an add-a-leaf, it would be placed in the pack on top of the factory overload between the overload and the rest of the arched springs.
  6. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    Yup, that bottom one is just the factory overload. When I added my AAL it went between the main leaf and the second leaf. I had to cut it down to size per the directions. So maybe it does have an AAL but you can't see it cause it looks like the rest of the leafs. :crazy:
  7. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Yep, overload springs
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    You need to get a closer shot at one side leaf pack.
    That bottom flatter spring is the factory overload, like the others quoted.
    If there is another spring about the same thickness as the bottom OL leaf, and if its curved the same as the spring pack, then it is the AAL. But if all the leaves above the OL are the same thickness, then I've got to say the lift is only 4" as indicated by the lift blocks themselves.
