What is this pinion seal guard thingy on my 14bff?? squeaky..
Discussion in 'The Garage' started by XHitman396, Aug 11, 2006.
  1. XHitman396
    XHitman396 1/2 ton status
    May 3, 2002
    620
    Broken Arrow, Oklahoma
    so after gettin the new axle in, i realized this thing on the pinion that appears to be some sort of pinion seal guard i think. but it's not fixed to anything, so when i drive it just slings around the pinion and makes a helluva rattling noise. i looked around and see no obvious way it attaches to anything. Anybody know what exactly/how exactly this thing is supposed to be attached to or how to make it stop rattling.. thanks.
  2. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Duct tape!!!
    Hee-hee...................me too!!!
    12bolt though!
  3. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    Just cut it off. It originally attached to the pinion yoke with a press fit or sometimes spot welded on. It is more of a shield to help protect the pinion seal and isn't really needed.
  4. sarasotausmc
    sarasotausmc 1/2 ton status GMOTM Winner
    Dec 16, 2003
    769
    Jacksonville NC
  5. XHitman396
    May 3, 2002
    620
    So it's unnecessary?? hell i think just spot welding it back on the pinion would be easier... thanks..
  6. fabjunkie
    fabjunkie 1/2 ton status
    Aug 23, 2005
    1,580
    Dallas Outskirts
    Yep, cut it off.
  7. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    been mentioned before from a few other people too, i had the same issue after i hit it on something while wheeling...I just tacked a few spots around it with the welder,,,all quiet now :D
  8. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
  9. Melvin
    Melvin Registered Member
    Apr 15, 2005
    9
    Washington
    I'm in nthye middle of replacing the seal and bearing on my 14 bolt. Do I need to take the cover (8 or so bolts) off the get the bearing and seal out? (pinion) I know it's probably a stupid question.
  10. 4xcrazy
    Oct 31, 2003
    9,471
    5
    To get the bearing out, yes, and have "fun" i needed to have a press to push the original pinion out from the bearing and housing...
    to replace the seal no, but you will need to break the pinion nut loose, remove the yoke, then you get to the seal and pop it out.
  11. Melvin
    Apr 15, 2005
    9
    Washington
    So, do I need to take my ring gear,spidergears,etc. out also for the pinion bearing or does it come out the frongt? (How big of a pain in the rear is this bearing job?)
  12. 4xcrazy
    Oct 31, 2003
    9,471
    5
    to do just the pinion bearing, no, the ring gear assembly can stay in, the 8 bolts come out, then the pinion assembly comes out towards the front of the vehicle, ,,,,,be sure to break the pinion nut loose before removing the pinion housing though.
  13. Melvin
    Apr 15, 2005
    9
    Washington
    Alrighty I'll give it a whirl... wish me luck! :doah:
  14. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    You'll need a new crush sleeve to set pinion preload back to spec or you risk eating bearings and or gears.
